+ Reply to Thread
Results 1 to 18 of 18
Thread: need some suggestions
    Xtreme Enthusiast jetjaguar's Avatar
    Nov 2004
    new jersey
    0
    im going to watercool my first system and just needed some suggestions on parts .. systems specs are in my sig ..
    i was planning on getting
    dtek fuzion with nozzles
    micro res
    thermochill pa120.2 or a swiftech mcr220
    no idea on pump
    no idea on gpu block
    originally i was set on getting a thermochill rad .. but it seems they are impossible to find in the usa and some shops i spoke to said they wont be getting them anymore
    all of this will be in a silverstone tj09 .. so im limited to a 120 x 2 rad .. i could add a second on outside the case with a rad box
    which gpu , and pump do u guys recommend .. also i guess a rad as well
    thanks in advance
    Intel Core2Quad Q6600 @ 3.6 | Thermalright Ultra Extreme
    EVGA 780i SLi
    8gb ADATA 4x2gb DDR2 800
    Evga 260gtx core 216
    Western Digital 300gb Raptor x 2 | Seagate 7200.11 1.5tb x 2
    Klipsch 5.1 Ultra Promedia
    Corsair 1000hx
    Lian Li TYR PC-X500
    Dell 3007fpw 30" Widescreen LCD
    Dec 2007
    0
    just the cpu will need a pa120.2 if you're adding anything else you need the .3
    Nov 2004
    new jersey
    0
    really ?
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
    Xtreme Mentor Nate P.'s Avatar
    Sep 2007
    Monterey Bay, Calif.
    0
    Quote Originally Posted by Isriam View Post
    No way man. You can definitely have the CPU and GPU in the same loop with the PA120.2.
    For the pump, the Liang D5 (Swiftech MCP-655) or the MCP-355 w/ aftermarket top are great choices.
    MCW-60 for the GPU block, unless you absolutely must have a full-cover block.
    Nov 2004
    new jersey
    0
    Quote Originally Posted by Nate P. View Post
    thanks .. if a 120.2 wont be enough ill have to ditch my case for another one ..
    if i cant get the 120.2 thermochill which other one would u recommend .. im using scythe s-flex fans
    i know the swiftech ones are half the price of the thermochills
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
    Sep 2007
    0
    The MCR-220 is a good rad, but with a quad-core and a GPU, you'll be pushing it.
    BTW, the PA120.2 is in stock at Sidewinders.
    Dec 2007
    0
    i have a pa120.2 and for a fact at 3.6ghz 1.45v the pa120.2 is pushing it. i hit 65 easily. i have 4 yate loons in push/pull with shroud.
    Nov 2004
    new jersey
    0
    but the thermochill should be able to handle it ?
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
    Sep 2007
    0
    Quote Originally Posted by jetjaguar View Post
    Yes.
    BTW, is your Q6600 a G0 or B3? It makes a big difference in regards to heat output.
    Nov 2004
    new jersey
    0
    b3
    with my ultra extreme .. at 3.2 it hits like 65
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
    Sep 2007
    0
    b3
    Hmm... just don't take the voltage too high then.
    Nov 2004
    new jersey
    0
    yea vcore is at like umm 1.35
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
    Nov 2004
    new jersey
    0
    looks like im gonna have to just switch cases
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
    Xtreme Mentor
    Feb 2007
    0
    B3 and 8800GTX in the same loop, eh? I'd say forget a full cover gpu block with that size rad.
    If you're switching cases, get into a PA120.3 or GTX for best. Swift 320 rad if econimising.
    V-Twin WIP
    Q6600 G0
    EVGA680i
    4GB OCZ
    8800GTX
    LC - Dual loops.
    Dual 20.1 monitors.
    Sep 2007
    0
    Quote Originally Posted by Jedda View Post
    Yep, or possibly forgo the GPU altogether? Slap a nice aftermarket air cooler on the GTX and water cool just the CPU would maybe be the better route...
    Xtreme Mentor Talonman's Avatar
    Sep 2007
    Ohio
    0
    There is always external as an option: http://www.xtremesystems.org/forums/...=160606&page=2
    The TJ09 is such a nice case to not use...
    Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
    Nov 2004
    new jersey
    0
    yea i dont know what im gonna do .. maybe ill sell off the q6600 and get a g0
    and maybe ill just sell the tj09 for a tj07 so down the road i can do a nice watercooled setup in it
    EVGA 780i SLi
    Corsair 1000hx
    Lian Li TYR PC-X500
  18. #18
    Sep 2007
    0
    I don't know anyone that would get a B3 when G0's (new) are going for ~$250.
+ Reply to Thread
