Results 1 to 13 of 13
Thread: G0 Q6600 HSF for LAN mobility
    Dec 2006
    I pack up my stuff and drive 5-30 miles every other week to LAN parties. This means my case is moved a lot. I'd like to get a good HSF for it but I have heard that large HSF units such as the Thermalright Ultra 120 Extreme are not for systems that move a lot.
    I would like to be able to run my Q6600 at just 3GHz and have an HSF that isn't going to rip my mobo in half when I move it.
    Thanks.
    -PC-
    Cooler Master Centurion 5 | Antec TPII 550W Gigabyte GA-P35 DS3L | Intel Q6600 | G.Skill 2x1GB DDR2 800 | eVGA 8800GT Superclocked | NEC DVD/CD burner | WD 80GB SATA, Seagate 250GB SATA, Samsung 500GB SATA
    -Audio-
    Creative Zen Vision M | Logitech Z4 2.1 | Grado SR60 w/Senn HD414 pads
    -Displays-
    Samsung 226BW S-panel, Viewsonic VX924
    AIM-spyderbox56
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    mini scyth
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme Mentor
    Aug 2006
    HD0
    Silverstone Nitrogon NT06 Lite according to the pinned thread
    Aug 2007
    Cumming, IA
    Honestly any heatsink should be fine. If mounted properly I've never heard of anyone actually damaging their mobo due to a heavy HSF. It's all just speculation. Now the heatsink contact might get ruined every once and a while if you move it a lot, but that's pretty easily remedied by a reapplication.
    XBOX Gamertag:Fujimitsu - I'm lonely, be my friend!
    Xtreme Cruncher
    Apr 2006
    Tampa
    Quote Originally Posted by Fujimitsu View Post
    I agree stick with the TRUE and just be careful when you are moving it around.
    Workstation :
    Q6600 @ 3.2ghz/Scythe Infinity (Screw mount mod)
    GA-P35-DS3L (F7)
    4GB G.Skill @ 400mhz 4-4-4-12
    BFG Nvidia 7600gt
    WD 250GB SATAII 16MB (OS/Programs)
    Seagate 250GB SATAII 16MB (Storage)
    NEC DVD+/-RW
    Antec NeoHE 550W
    X-Fi Xtreme Music
    Razer Copperhead
    MS Natural Ergonomic 4000 (Best KB ever!)
    Windows 2008 Enterprise Server x64
    Laptop:
    Dell Latitude D610 - Pentium M 750 1.86Ghz / 1GB RAM
    Xtremely Hot Sauce
    Sep 2007
    New York
    Depending on your case, you can jury-rig a solution to fully support the large heatsink. One easy way would be to run relatively strong string to other parts of the case. I have a Scythe Infinity--if I were to do it, I'd probably run string from my 5.25" bays to a power supply screw (top) and a string from the 3.5" bays to the expansion slots. There are plenty of screws you could use to string internal support to. As it is--you only need to stop the top from moving. Tie it down on each end, but don't tie it directly to the heatsink (loop it around).
    That, or when moving it keep it on its side with the heatsink motherboard & heatsink to the ground. You could grab some other coolers that would work, and I hear that the Scythe Mini Ninja is probably a better option for that.
    My toys:
    Asus Sabertooth X58 | Core i7-950 (D0) | CM Hyper 212+ | G.Skill Sniper LV 12GB DDR3-1600 CL9 | GeForce GTX 670-2048MB | OCZ Agility 4 512GB, WD Raptor 150GB x 3 (RAID0), WD Black 1TB x 2 (RAID0) | XFX 650W CAH9 | Lian-Li PC-9F | Win 7 Pro x86-64
    Gigabyte EX58-UD3R | Core i7-920 (D0) | Stock HSF | G.Skill Sniper LV 4GB DDR3-1600 CL9 | Radeon HD 2600 Pro 512MB | WD Caviar 80GB IDE, 4TB x 2 (RAID5) | Corsair TX750 | XClio 188AF | Win 7 Pro x86-64
    Dell Dimension 8400 | Pentium 4 530 HT (E0) | Stock HSF | 1.5GB DDR2-400 CL3 | GeForce 8800 GT 256MB | WD Caviar 160GB SATA | Stock PSU | (Broken) Stock Case | Win Vista HP x86
    Little Dot DAC_I | Little Dot MK IV | Beyerdynamic DT-880 Premium (600 Ω) | TEAC AG-H300 MkIII | Polk Audio Monitor 5 Series 2's
    Aug 2007
    Cumming, IA
    Quote Originally Posted by Bobsama View Post
    Zip-Ties
    Oct 2007
    Georgia/TBILISI
    Volucris
    you need someyhing compact and ''strong''. i think it is Xigmatek HDT-S983 (it is only 400g).... than comes Scythe Mine (with fans it is 560g).
    OCZ Vindicator da Themaltake V1 also not bad...
    you want 3 GHz... it is not problem for all these ones...
    GeoOC(TM)
    Team Xtreem DARK - F.A.Q. - 8 vs 6 Layer
    Dec 2006
    ultima 90, small and powerful
    Engineering The Xtreme
    Feb 2007
    MA, USA
    just put a backplate on the true and you will be golden, I don't think you could break the board with a proper backplate, unless its a cheap thin PCB
    Dec 2006
    So as long as I handle the case carefully, the Ultra 120 Extreme should be fine?
    I usually pick the case up in a vertical position and carefully set it down in a horizontal position on my back seat where it won't move much.
    I've heard that due to defective mounting supplies from the manufacturer, the Ultra 120 Extreme has a bit of "play" on the board. I would imagine that could effect the damage possibilities if a sudden and rapid movement of the case was to occur.
    Any insights on that?
    -PC-
    -Audio-
    -Displays-
    AIM-spyderbox56
    Xtreme Cruncher
    Apr 2006
    Tampa
    I think all large heatsinks like the TRUE move a little bit, but if you are careful I do not believe that it would cause too much damage to your motherboard.
    Workstation :
    GA-P35-DS3L (F7)
    BFG Nvidia 7600gt
    NEC DVD+/-RW
    Antec NeoHE 550W
    X-Fi Xtreme Music
    Razer Copperhead
    Laptop:
    SLC
    Oct 2004
    Ottawa, Canada
    there havent really been cases of people breaking their boards because of heatsinks. Any will do fine... I used to drag my comp around to such distances with a single stage on cpu lol
