+ Reply to Thread
Results 1 to 15 of 15
Thread: QoS for Gaming
    Jan 2006
    0
    QoS for Gaming
    Does anyone know if QoS should be enabled in my network adapter, specifically for gaming? I don't experience any lag and my router logs show no packet loss. Just curious as to if there would be any benefit?
    The Voice of Reason Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    0
    Yes it should be enabled, no reason not to.
    Windows 7 + SSD:
    Mode: AHCI, default Microsoft driver or latest Intel RST
    Defrag: Off
    Hibernation: Off (use Sleep mode, recommend a UPS)
    Indexing: On (it only indexes a few locations, not your whole system unless you tell it to)
    Page File: On (set to the minimum of 16MB if you have a large amount of RAM, disabling not recommended)
    Prefetch: On
    Superfetch: On (RAM is always faster than an SSD - use it)
    System Restore: Off (with regular backups)
    Browser Cache: RAM Only, Disk Cache Off (How to with Chrome)
    Documents, Music, Pictures, Videos, Downloads to HDD (Public Libraries too, see above link about junctions)
    UAC: On!
    Moderator
    Nov 2006
    0
    Quote Originally Posted by Nicksterr View Post
    From my experience unless you are in a corporate enviroment (and have a fully AD/GP deployment) it makes no difference whether there is a QoS binding to a network adapter or not.
    ..I guess its slightly more tidy if you uninstall it.
    Oct 2003
    Lincoln, NE
    0
    QoS has greatly increased the responsiveness of all computers on the network when browsing the web, while heavy network traffic is underway (uTorrent).
    It prioritizes information passing through the network. I have uTorrent set to 250 priority so basically everything else goes virtually uninterrupted. And you know how torrents can hammer a router with work.
    If you have nothing else going there is probably no benefit.
    Windows 7 + SSD:
    Defrag: Off
    Prefetch: On
    UAC: On!
    Moderator
    Nov 2006
    0
    How have you set uTorrent to 250 priority(using gpedit)? and ensure that gets "respected" all the way to your router?
    It has always been my belief that unless you have windows QoS Packet Scheduler at both end of the link or a router that is DSCP enabled it is effectively useless?
    (source:http://www.dslreports.com/faq/3688)
    And that in a domestic enviroment QoS Packet Scheduler is better disabled:
    http://www.petri.co.il/increase_inte...windows_xp.htm
    Please let me know if you have had any success with your setup and any details would be helpful.
    thanks!
    c[_] STEvil's Avatar
    Nov 2002
    Alberta, Canada
    19
    QoS is useless pretty much. Great example of a program that will kill your router whether enabled or not is STEAM. Sends out thousands of packets of data when updating/refreshing server list which crashes many routers.
    Heatware || 01.01.08; AND 111.2%
    Dead Z7S-WS? Click!. || XS Z7S-WS Thread || Current Dead Asus Z7S-WS count: 26+ ($15,000 in dead motherboards).
    All along the watchtower the watchmen watch the eternal return.
    Want to use my Anti-asus logo? Go ahead, but use this link please!: http://i853.photobucket.com/albums/a...sus/noasus.gif
    Bring back the game. http://reclaimyourgame.com/. EA are mean.
    Xtreme Mentor YukonTrooper's Avatar
    Sep 2006
    0
    QoS is good if you have the need for it. Most people don't though.
    Steam is a biotch. Sends out tons of UDP packets to refresh servers. The problem is that it doesn't close them right away after pinging the server, so some routers flood because their ip table fills up so quickly. STEvil do you know any wireless routers that don't track connections? I'd like to replace my WRT54GL so I can avoid this Steam bullcrap.
    For my part I know nothing with any certainty, but the sight of the stars makes me dream.
    Moderator
    Nov 2006
    0
    Qos is great! but QoS Packet Scheduler and any MS implementation of QOS is really bad.(with the possible exception of ISA Server)
    Most routers use stateful packets inspection and maintain a state table, routers that crash normally during steam/p2p are normally doing so because the state table is too small (there are other reasons of course ) and becomes overwhemed, and these days you will be hard pressed to find a router that is not stateful (if at all)
    Your best bet to find a new wireless router which does well for p2p traffic like this review:
    http://www.tomsguide.com/us/which-ro...eview-686.html
    I have also used the d-link_dgl-4300 and had good experiences with p2p,steam and gaming.
    Nov 2002
    Alberta, Canada
    19
    Friend has one that is rebadged as a "Telus" unit.. dsl router + wireless (no antenna's). I forget the model, though.
    Sometimes it'll drop the net, sometimes it wont.. hasnt for quite a while since I turned it on its side though.. heavy use with 3 pc's on steam/torrent at any given time
    Xtreme Cruncher
    Jun 2006
    Land o' 10,000 lakes
    2
    Dig up some old PC and throw Smoothwall on it. Then get rid of those routers and get a switch. Latest version has QoS built in and I haven't been able to crash the thing once (uTorrent while playing TF2 worked). If you need wireless I don't know what to say.
    I'm almost always available on Steam to chat. Same username.
    Xtreme Enthusiast halo112358's Avatar
    Dec 2005
    Peoples Republic of Berkeley (PRB), USA
    1
    How do you set priority of applications with gpedit? I've been googling it for the last couple of hours and the only thing I'm finding is garbage about the 20% bandwidth reservation myth.
    core i7 920, gigabyte EX58-UD5, 4870x2
    DDC3.2 > PA120.3 > DD4870x2fc > Fuzion v1 > PA120.2 > EK Res
    Moderator
    Nov 2006
    0
    Quote Originally Posted by halo112358 View Post
    Under Computer Configuration->admin templates->network->QoS packet Schedualer.
    In there you can sent tell XP the DSCP values of Best effort traffic for example.
    But as above, you have to have a "proper" environment in place.
    I still have no idea how Soulburner set priority to 250 and how that ties in with the
    QoS packet Schedualer?
    I have the feeling that Soulburner has either HTB or CBQ running on a router and that is how he is doing it.
    If you want QOS or Traffic shaping use this freeware:
    http://bandwidthcontroller.com/trafficShaperXp.html
    Oct 2003
    Lincoln, NE
    0
    It's in the router.
    It prioritizes all traffic ahead of uTorrent so web browsing is mostly unaffected by the high amount of simultaneous connections (50-200).
    Windows 7 + SSD:
    Defrag: Off
    Prefetch: On
    UAC: On!
    xtreme energy kiwi's Avatar
    Oct 2004
    Europe, Latvia
    0
    QoS is a typical router feature and regular PCs don't usually need it. The only reason I can think of if you use torrent or download something and wanna game without interrupting it. Then you can use some software to do it but I still dont suggest it. Just pause/stop download and start gaming, after that continue download
    Dec 2005
    1
    I'm interested in setting high priority for packets generated by particular applications (games) on a congested network (multiple people torrenting).
    Personally, it's a pain in the ass to track every port that a game uses and then setup priority rules on the router - that's why I was curious about setting per-application QoS priority directly on the client machine.
+ Reply to Thread
