i have seen some cases that are nicely polished and i was wondering what the process is to get a case that is all polished? i am thinking about doing it to my case and i would love to get some steps from the pros
Lots and lots of time but you first have to strip the paint (obviously, then start sanding with about 600 grit and work your way up to a really high grit sand paper like 2000 or 2500 grit. From that point you probably have to use a polishing compound and a buffer but I'm not sure...
- Thermaltake Mozart-TX
- Corsair 620HX
- Gigabyte 965P-DQ6
- Intel C2D E6400
- 2 x 1GB G.Skill PC8000
- eVGA 7800GT CO 256mb
- 2 x 320GB Hitachi - RAID0
- DD TDX - CPU
- DD Maze4 - GPU
- DD Laing D5
- Black Ice 240mm RAD
The Lian Lis are anodized aluminum, which is going to make the process a lot harder. You are either going to have to get it sand blasted, or spent hours getting the anodization off. If you want to do it yourself, you are going to have to start with a pretty low-grit paper. I'd say 400ish. Then slowly work you way up to 2000 or so. Then you'll need a high speed polisher to take it up to a nice shine.
Sand the whole thing down with a mouse sander using 400 grit. Once you have done that work your way up the grits using 800, 1000, 1500, 2000, 2500 ( if you can get 2500 )
Make sure you remove all the left overs with a lint cloth after each grit type. Once youve done that you really need a polishing wheel.
Their is alternative ways
You might find this an interesting read for getting a mirror finish using paint.
http://www.mnpctech.com/case-mod-pai...od-how-to.html
New specs to appear here >.< sometime soon.
in the mean time i'm using me shuttle
tis fast enough for now.....
<doh in me dream tis slow> no vmod / no PSU mods / no phasechange how can it be fast
Inside of the case is going too be really hard to do and will take hours and hours of hard labour to get a decent finish.
Yeah...would almost be easier to just have the chassis dipped in chrome :P
- Corsair 620HX
- Gigabyte 965P-DQ6
- Intel C2D E6400
- DD TDX - CPU
- DD Maze4 - GPU
- DD Laing D5
The inside of Lian Lis is really easy. Polish it with rubbing compound and then buffing compound, then metal polish. Instant mirror.
I've owned quite a few Lian Lis, so I've had more than ample opportunity to try it.
Don't agree. There have been a few threads about this. The difference between a sanded-to-polished interior to just one that went straight to polish is huge.
If you want to do the interior you do not need to start at such a low grit. Start with 1000 or so. Make sure you use a sanding block and always use clean soapy water when sanding. If there are any deeper scratches keep with the same grit until they are gone. Then move up to the next grit. Then once you get to 1500 bring out the polishing compound. You can do it by hand as it is hard to get an orbital polisher inside a case.
Here is a pic of the interior of what my V1000 looked like.
Anodizing doesnt take long to get rid of though with a sander and some low grit paper, plus you can use a polishing wheel to finish it off.
Inside is more of a PITA as you will have to do a fair bit by hand to get a decent finish all over.
Far from it, many ways without flattening back every coat including the very crafty (paint + lacquer clear coat + paint) technique
Yes time consuming but its down to the absolute quality your after vs the effort you need to put into it personally.
Anyway as for wet & dry paper I do highly recommend Meguiars Unigrit Finishing Papers goes up P3000 or P3500 for finishing off before you go down the route of cutting compound / buffing compounds & glazes/waxes.
I did well enough on my classic mini door http://brittech.co.uk/minidoor.jpg
This stuff works great.
http://www.eagleone.com/pages/produc...=1006&cat=5006
If you do want to polish an anodized part Oven Cleaner removes anodizing much more rapidly than sanding
But the interior as stated above is just plain alu so it should go quickly.
20 Logs on the fire for WCG: i7 920@2.8 X3220@3.0 X3220@2.4 E8400@4.05 E6600@2.4
Make sure if you use oven cleaner to get the lye based cleaners the other types won't cut the anodize off and have plenty of ventilation and eye and skin protection.
Donate to Xtreme Systems!
Now Showing:
Gigabyte x48-DQ6, Q6600,OCZ 1066 Reapers,2 750gb seagate 7200.11 hd, BFG 8800GTS 512,PC P&C 750 Quad psu, 24" Sceptre lcd, Antec 900
my wife's system now!
Intel C2D 6400, Zotac Matx mobo, 1gb kingston mem, Nvidia 7050, I Feel really Good now!
Jon C2D 6600 Zotac mobo 1gb mem............................................... ................. HTPC qx6700@3.0ghz
Annabelle Amd 3800+@2.4ghz, Biostar mobo, 1gb ocz pc4500 beta's................. Optyx2 opty165@ 2.1 ghz
'Want a real high?
Come crunch WCG and you'll feel like your on QuadCaine"
First loops are like first sex, all hands and thumbs till you figure out what goes where, then it's what ever works best for you.
there is a soap you can use to remove anodizing.
i forgot the name. but its a household kitchen cleaner.
should be a stove cleaning related soap.
Intel Core Duo T2500
Aopen 945GMt-FA
2x1GB Transcend DDR2-667
2.5" Fujitsu 80gb SATA
Slim DVDRW
Istar S3
Lye based soap has no lye in it. The lye has all been consumed by the fat during a process called soapification while the soap is curing. I own a soap company. No, I'm not jerking thine chain.
As to refinishing ALU cases, if you talk nice to the local custom rim rebuilder, he can do things to a case you simply cannot at a surprisingly affordable price.... including powder bonding or cutting a logo.
Doing it yourself is always more rewarding however.
"Foldin, Foldin, Foldin...keep those benchers foldin..." (Lyrics by Angra, Music is Rawhide)
BOYCOTT MIR's
get the rotary polish 'thing', not for car - i forgot the name .. use the wool surface
use polishing compound, then glaze, then maintain it with wax (preferably carnauba bee wax ... sounds overkill .. but u can also put it on ur car)
if u're doing 1st time .. it's better u tried out on a piece of metal, steel .. whatever .. go it slow, speed is for pro ..
if u dun wan all this troubles .. just get ur casing to the car polisher .. they'll do it for a small fee .. (casing is much smaller than a car.. if u omit the mainframe)
