hi i would like to know whats the best air cooling system
for my zalman fatal1ty. thank you my computer specs are in my signature
Mobo::::::::::::::::: Gigabyte X38-DS4
Cpu::::::::::::::::: q6600 2.40 ghz
hd:::::::::::::: SeaGate sata 320x2gb 7200rpm
Gpu::::::::::: GeForce 8800 GTS 512mb
Ram::::::::: A-Data 800mhz DDR2 4Gb
Psu:::::::: Thermaltake ToughtPower750 watts
Case::::: Antec 900
mice:::: LogItech G5
Cs::::: Stock
Kb:::: Logitech G15
mon: 19inch Vw192 Asus LCD
Tuniq Tower.
Main Rig:
Q6600 G0 @3.7ghz 1.425V - EVGA 680i A1 (Vdroop mod) - 4GB G.Skill HZ DDR2-800 @1000mhz - EVGA 8800 Ultra SLI @710/2460mhz - 2x WD Raptor X 150GB RAID 0 - 2x WD 500GB RAID 1 - 1x WD 320GB eSATA External - SB X-Fi XtremeMusic - Enermax Galaxy DXX 1000W - NEC 16X DVD±RW DL - 2x Dell 2405FPW (Dual monitor w/ SLI!) - ATI Radeon X300 - MM U2-UFO Horizon
Dual loops:
D-Tek FuZion (Bowed) - PA120.3 - Dual DDC2+ w/ PT tops - Swiftech MicroRes - Distilled w/ Red UV dye
2x EK FC8800 - DD680i NB - PA120.2 - Dual DDC2+ w/ PT tops - Swiftech MicroRes - G11 UV
Temps: 28-29degC idle / 46-48degC load with MX-2! Pics of my build!
Dedicated Cruncher:
Lapped E6600 @3.6ghz - MSI P35 Platinum - 2GB Crucial Ballistix DDR2-800 @933mhz - MSI 8500GT - 320GB WD - Lapped Big Typhoon - Seasonic M12 700W
well you could go with the Zalman Fatal1ty FS-C77 to match with your case
or you could check these threads out:
http://www.xtremesystems.org/forums/...d.php?t=106971
http://www.xtremesystems.org/forums/...d.php?t=158187
when u go air and want the best, there can be only 1: Thermalright Ultra-120 Extreme
• DFI Lanparty LT X48-T2R
• Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
• eVGA 8800GTS (G92) 512MB {stock}
• Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
• Lian Li PC-V1000 {modded}
• Corsair HX 620W
• Creative X-FI ExtremeMusic
• Western Digital Raptor X 150GB
• Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
Thermalright
Ultra-120 Extreme
MAIN: 4770K 4.6 | Max VI Hero | 16GB 2400/C10 | H110 | 2 GTX670 FTW SLi | 2 840 Pro 256 R0 | SB Z | 750D | AX1200 | 305T | 8.1x64
HTPC: 4670K 4.4 | Max VI Gene | 8GB 2133/C9 | NH-L9I | HD6450 | 840 Pro 128 | 2TB Red | GD05 | SSR-550RM | 70" | 8.1x64
MEDIA: 4670K 4.4 | Gryphon | 8GB 1866/C9 | VX Black | HD4600 | 840 Pro 128 | 4 F4 HD204UI R5 | 550D | SSR-550RM | 245BW | 8.1x64
if you wipe ass with dollar notes then yes TRUE, but if on a budget look else where... check thread at top of this forum on best coolers.
Gaming Rig
Intel E6300
Intel Mobo
2 Gig OCZ 800 (800 5,5,5,15)
Saphire Ati 4870
22inch LG Flatron W2230S
I wipe my ass with toilet paper, and I still bought a TRUE.
read some of the stickys... per my standard issue response
ha tuniq tower. what do you think this is? 2006???
CPU:X3210 G0@3.6 (8x450 1.48v)
MOBO: Asus P5K Premium, bios 402
RAM: 4x 1GB DDR2-1066 @ 1080 5-5-5-15 2.3v
CASE: antec 900
GPU: XFX GeForce 7900gt @600/1900
PSU: silverstone OP1000
Cooling: MCP655, Apogee GT, MCR320-QP-K
Processor: Intel 2500K 4.4ghz
Motherboard:Asus Sabertooth P67
Cooling: Prolimatech Megahalem 3x120mm fans 2x Icages, 2x92 mm fans, 140mm PSU fan
Memory: Mushkin Redline (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1666 6 8 6 24 t1
Video Card:Asus Matrix GTX 580 1.5GB
Harddisk: Wester Digital Black Edition 32MB 7200 RPM 1TB SATA 3.0 ,CAVALIER SE 16MB 640GB SATA 3.0 DRIVE
CD/DVD Drive: 1 BLACK LG LIGHT-SCRIBE DVD BURNERS
CRT/LCD Model: BLACK ASUS 25 INCH MONITOR 50000 TO 1 RATIO 1920x 1080P
Case: Thermaltake Armor Series VA8003BWS Black Full Tower Case solid side panel.
Sound Card: Sound Blaster Live 24 Bit 7.1
PSU: Thermaltake Xt 850 watt SLI 140mm silent fan
Software Windows Vista Ultimate 64
Case::::: Antec 900
Cs::::: Stock
Kb:::: Logitech G15
no it is not I have both the enzotech won't keep my quad under 80c when using 1.50v. the ultra extreme keeps all 4 cores under 58c and is half as loud. The Enzotech is great for dual cores but cannot handle a extreme overclocked quad. My ultima 80 even beats the enzotech using only a 90 mm fan. read this review http://www.anandtech.com/casecooling...spx?i=3068&p=1
Is this it on NewEgg?:
http://www.newegg.com/Product/Produc...-120%2beXtreme
I don't see the work Xtreme anywhere in the title of the unit.
Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
I think the cooler will be limited by your case ....
Asus A8N-E, x2 3800+ 2.7Ghz@1.488v RmClk, TT Big Typhoon lapped, Zalman NB-47J, XFX 9500gt, Corsair 2Gb, Sony DVD, Samsung 1TB, Coolermaster Cavalier, Enermax 620w, Benq G2400WD, Logitech X-230, WIN7 64.
There is a cure.... it's called Prevention. .. And remember - the story being told is not always the one that best reflects reality….
http://www.sidewindercomputers.com/thulex.html here it is. notice it has 6 heatpipes on each side the Thermalright Ultra 120 has 4 heatpipes. The Thermalright Ultra 120 is still the second best air cooler.
Thanks.
The Xtreme is $56.95, and the regular is $59.99. Go figure....
Easy choice to make.
If you live in Canada, DirectCanada has the TRUE for 48.42. What a steal! : O
E7200 @ 3.4 ; 7870 GHz 2 GB
Intel's atom is a terrible chip.
Here is the Thermalright Ultra 120 for 39.00 and it is a very good cooler second best. At that price I would buy it instead.http://www.sidewindercomputers.com/thul1.html
Here is a review on it. http://www.frostytech.com/articlevie...articleID=2001
well if you could afford these specs (especially the Zalman case), then buying a TRUE would be no problem.Mobo::::::::::::::::: asus maximus formula
Cpu::::::::::::::::: q6600 3.0 ghz
hd:::::::::::::: Western Digital sata 500gb 7200rpm
Ram::::::::: Kingston Hyperx 1200mhz DDR2 4Gb
Psu:::::::: Thermaltake ToughtPower 850 watts
Case::::: Zalman fatal1ty
mice:::: Razer habu
Cs::::: cpu cooler: fatal1ty zalman fs c77 antec SCB
Kb:::: Razer turantula
hp::: Razer barracuda
mon: 19inch viewsonic
Corsa is right, i'm not sure how big the Zalman case is, just check if the TRUE would fit inside.
the best aircooling? well... there is the true, then the other thermalright products.. then nothing for a long time, then the rest.
in case you run into size issues with a true, the ultima 90 is much smaller but still performs good.
