What are respectable temps for Q6600 chips at load and at idle?
At what temperature would you begin to worry?
Approximately how much voltage starts to get very risky?
Thank you so much!![]()
65 C coretemp temperature readout per on full Prime load,
wouldnt pump more than 1,45V (real) into for 24/7 , but you will sooner run into temperature problems than high voltage problems with quads
Sometimes a good slap in the face is all you need
Bios my arss.....![]()
I can fix this problem with a hardware mod....![]()
Hipro5
"Overclock till death. Overclocking is life." Hipro5
Is that a SLACR (read GO) CPU or a B3 ?, really high temps on 2 cores, you sure the CPU cooler is well seated ? I also have some variation but mostly on one core that is about 4-6°C hotter than the rest , yours is over 12 degrees which seems much to me or you got a very bad IHS or bad mounting...
I presume those temps are with the stock intel cooler ?
And indeed 1.45 or such is max volts on air to be on the safe side, but those with a beefy CPU cooler and not the stock Intel... so if you want something more out of the CPU it's time to invest in decent cooling....
Question : Why do some overclockers switch into d*ckmode when money is involved
Remark : They call me Pro AsusSaaya yupp, I agree
From what i have seen L737B's are among the best. Good luck with that chip.
i5 2500K @ 4.7ghz 1.32v(+.010 offset LLC set to 4) / ASRock P67 Extreme4 (B3) / 2x4gb Samsung Green MV-3V4G3D @ 1866mhz 1.35v / AMD HD 6850 1gb /2x150gb Velociraptor Raid 0 + 500gb WD Green / Corsair TX 750watt V2
Intel i7 3770K (4.8Ghz@1.36v) ~ Asus Maximus V Gene ~ 8Gb G.Skill Ripjaws X 2133 C9 (@2400 C10) ~ Asus GTX 670 DCUII (1230/7000) ~ Samsung 840 Pro 128Gb ~ WD Black 1Tb ~ Corsair AX 850W ~ X-Fi Titanium Fatal1ty ~ Epoz Aktimate Mini ~ Ducky Shine Blue Led /w MX Red ~ Logitech G700 ~ Samsung S27A850D 27" (2440x1600) ~ SilverStone TJ07B-W
WaterCooled by XSPC Raystorm ~ TC PA 120.3 + 3xAP 15 ~ MCP655 with EK-D5 X-Top Rev.2 ~ EK Multi 250
Powered by APC Smart-UPS SC 1500 ~ MGE ellipse premium 500
x9 Multiplier , 355x9 FSB, 1.32V.. What im using at the moment runs sweet on a
L740A630 SLACR
Its a G0. I believe its well seated- it came with four screws that come out through the back and little springs/nuts to hold down the CPU cooler. Those temps are with an apogee GT cooler.
Hmmm define IHS?
I'm also using Coollaboratory Liquid Pro as my thermal compound.
Either your IHS (Integrated Heat Spreader) is whack from the factory, you have a bad mount, or you did not prepare the CPU and waterblock surfaces for the LMP.
The P5K premium is a great board for doing 3.6Ghz with a GO at decent volts. What is the "vid" on your CPU?
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
Ok so I reseated the processor again-- this time I just globbed on the coollaboratory pro thermal material. I was always told that less is best with thermal interface material so I always took a thin drop and spread it out as much as possible. This time I just pup a nice little glob on there and let the pressure of the headsink do the work.
43/47/40/40 load (1.288v CPU-z, approx 1.315 Bios)
P.S. How do I turn my processor up more without having to turn the ram up? I'm at the max divider I believe (333Mhz) such that 9*400 = 3600 and if I run that 1:1 my ram runs at spec. I'd like to keep the ram in spec but up the processor.
I think you're applying the thermal compound wrong. I tried to do it the AS5 way and do a line across the cores and that got me to 80C+ so what I did was apply it all around the processor and get a credit card and make sure all parts were ever . That got me to down to 36C Idle stockI use Tuniq TX2 grease , best 1$ I've ever spent.
Asus Maximus Formula SE (BIOS 907)
Q6600 G0 (@ 3.2GHZ @ V1.320 )
Crucial Ballistix DDR2 800 4x1GB (2 Tracers) @ 1200MHZ
Thermaltake Toughpower Modular 750W
Tuniq Tower 120 / Tuniq Thermal Grease TX-2
BFG 8800GT OC
Cooler Master CM690
Maxtor 7200.10 320GB PATA
WWW.LEOFTW.COM
If I have to run my memory at 800 Mhz, it is not possible to have an FSB > 400?
I want to try 4Ghz CPU, 800 MHZ memory. Possible?
Hipro5
