yeah the large radiator fan i got...
mentally confused and prone to wandering
doing final vacuum right now. at 56 microns atm :O jesus christ. i think my vacuum guage is broken or something... i didn't believe it so i hooked up in line as close to the system (yeah oil gets on sensor but if i clean it regular should be fine). having a hard time finding's a good 1/4" t line. 56 microns still
hope to finish the tuning tonight. will be tuned for 230 watts.
regards
finally a bit of an update.
delay is-
1) blew fuse
2) didn't have fuse, so i started re-doing wiring
3) didn't have new psu, took 2 weeks from hong kong
4) went to the nederlands, overlapped with the psu from hong kong.
Nothing is screwed down, the wiring still looks messy. Its because every wire is about 6" to long on purpose. once all locations are decided it will be cut to exact length.
a lot of wiring...
need to finish wiring the 12vdc, and the grounds then i THINK im ready to start tuning again
regards
well thread revival.
Want to work on this again:
Subsequently i am going to:
Remove all wiring from build
Remove from case
Remove gauge
Remove HPCO
Remove compressor
Braze in larger compressor (9.1k btu)
Pressure test
Vacuum
do some super quick wiring (walt look away!, jk no open connections)
Try with pure r290 and see what i can get her to hold.
Will you be using your new case? I would recommend R-22 with those badass compressors (which are IMHO total overkill for an SS unit, but ... we're Xtreme ), you know it would hold great load!
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
hey!
maybe... The case i had made for this will end up in the trash most likely. its just way to flimsy...
r22? i have r290 and r402a... both a lot colder then r22 but no r22 here. its gotten pretty expensive in the past year!
just going to use r 290 too see how it holds a load. i don't even remember what cap tube i have in here!
When you use stranded wire "tin" the end with soft solder so the strands don't crush and separate when you tighten down the junction block screws or put terminals on the ends of the wire.
The Laws of Thermodynamics say:
Zeroth Law: "You must play the game."
First Law: "You can't win."
Second Law: "You can't break even."
Third Law: "You can't quit the game."
Do you wanna Play Thermodynamics ???????? I forgot "you must"
It dropped from 200 to 197 in 1 day. Im going to see if it comes back up in the temp swings.
cheers
EK Water Blocks R&D
ekwb.com
#1
Pentium D805 @ 3.4Ghz on GA-945P-S3
2Gb OCZ Gold 800 with XP Professional SP3
Ati X1800XT
550W Antec TruPower in Antec Sonata II
#2
Core 2 Quad Q9550 on GA-EP45-UD3P
4Gb Corsair Dominator 1066 with Vista Ultimate SP1
Asus 4850 TOP
750W PC Power & Cooling in ????
There is not enough electrical oulets in my room.
Best TF2 Quote:
"tomtom92 : wtf the enemy has a base IN our base"
I was having the same suspicions. 40 bar? er- 450 psig?
ill raise it to ~20 bar and see how it does. i have noticed that temperature does fluctuate the pressure quite a bit. Going to see if it keeps dropping tomorrow. Considering i used a lot of parts i had used around my garage its possible it had a leak somewhere (i brazed the evap months ago)
Are you pressurizing through just one side of the manifold?
Sometimes it will take a while for the pressure to equilize through the metering device. I would wait another day to see if it dropped anymore.
well f*ck my life.
ive wired it according to
http://www.panasonic.com/industrial/...s3r126b-1a.pdf
One thing to note- the 3 pins (c/s/r) on the compressor are not labeled and not lined up exactly as on the pdf.
Im using the overload from the 6,660 btu compressor.
The capacitor is a 40uf, 440vac (er- in that ballpark for volts).
When i try to start it i hear a buzzing noise but compressor does not start.
Ill try fiddling around with it some more, but does this sound like a dead compressor, dead capacitor, et cetera, bad wiring, et cetera?
ive 10x checked over my wiring and it seems to be correct.
cheers
hey man i might try a smaller capacitor most of the rotorys i have ehter use 230vac,270vac or 370vac never seen one that big even the ones i have for my 1hp rotorys are no biger the 370vac just toss on the 3in1 and see if it starts if it starts then you know it is not the compressor
