hello all! finally getting to a stage in this process, where i am starting to work. I still have so many things to buy and make, but i will start. This thread is pre-mature, but if you have followed any of my other work threads you will know i post lots of pictures. I am still waiting on condensers from nol and a mill for evaps, and some other odd-and end things.
What you see here is:
robinair 15600 vacuum pump(+oil)
30lb recovery tank
recovery unit(+filter)
uei dt-200 thermometer
15% brazing rods
2 core removers
1 core removal
spring benders
bending tool
2 pipe cutters
schrader valves
ball valve
cap tube cutter
anti-blowback valves
and several other things.
What you see here is 60 cubic feet of nitrogen with a nice regulator. In future i will invest in a flowmeter regulator in addition, but this is more then fine for purging now. this should be great for pressure/leak testing
50 feet of .25" refrigeration tubing, 10 feet of .031" cap tube, and 12 feet of .04" cap tube. (yes, very un-restrictive )
here is a mapp torch, oxy/mapp torch, oxy/mapp/propane bottles, flux, brazign rods, helmet and gloves. i actually have a oxygen acetylene kit on the way which will be very fun!
and last but not least, 2 compressors i have here, and desup... The desuperheater is made of about 60" of .25" tubing. Its crooked *cough* on purpose to increase surface area? ill straiten it out. I was having a hard time not getting the bending to crip while bending it around some 2.25" aluminum solid stock i had, so i had to do it by eye. the two compressors are a 5k btu rechi compressor, and a 5.5k btu LG hero compressor. The rechi is much smaller and is brand new, i will be using it(most likely) on this build. The LG is a stronger compressor, but it lost a lot of un-measured oil when i had my little r-22 accident and it think it would be a very discouraging first build to use it. Once i get the condensers i will be starting this build.
P.S. total price in tools so far is 1750$ and still need to get my 608 license, refrigerant, and other small things. Variac is on way, load tester is almost done. Will post pics of that when done.
P.P.S. Might swap compressor out to a matsu$hita 1/2hp rotary, or might incorporate one of those into another build.
Regards
