I setup again my water cooled rig
and the results are impressive
E6850 3000 @ 4200 mhz
vcore 1,55
ambient : 23 degree
idle just 33 degree
full load under orthos ( 2 core enable ) 66 degree ( usable 7/24 )
vcore 1,55
ambient : 23 degree
idle just 33 degree
just hanging on
no prob
just give me a little time
I want to run a spi 32m
after that u can get what u want
just hanging on
uh sorry mate
I could'nt get any temp readings @ 1,55 vcore cause it's not stable enough to run orthos
I could get that
@ 1,6 vcore idle
and 1,6 vcore load under orthos ( cause of the extra 0,05 vcore is the difference of 66 - 73 degree , thanx )
just hanging on
Your chip should be cool looking at the VID, but what does your chip do in temps at stock idle, any pics?
Looking at that, your hardware sensors looked borked because your 36C at 4.2GHz/1.61V after 5 min torture would mean you're getting sub-16C idle at 3GHz/1.28V in 23C ambient.
Can you give us EVEREST showing temps and Core Temps along with it at any speed/volts (idle)?
What temps does you chip idle at stock volts 3GHz? Any pics?
thermal measurement is 15c off the t-junction should be 85c not 100c therefore 15c lower than actual, in other words addd 15c to your temps. it is a common issue ,sorry to disappoint you.
QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
DFI LP LT X-38 T2R
2X HD4850's water cooled , volt modded
Thermaltake 1KW Psu
4x Seagate 250GB in RAID 0
8GB crucial ballistix ram
HWbot - Team: XtremeSystems
XS cruncher - Team: XtremeSystems
OCN Feedback
HEAT
*** Being kind is sometimes better then being right.
just hanging on
common problem been known about for months. for instance my phase unit is at -41 yet core temperature is reading -50 in everest, cpuz, etc. with 1.6v going to my cpu it is obvious that the temps are off.
DFI LP LT X-38 T2R
Thermaltake 1KW Psu
DFI LP LT X-38 T2R
Thermaltake 1KW Psu
@jimmyz
so can u give me any prog ( exclude speed fan it freezes my system )
so I can give you whatever you want
just hanging on
nothing to do just add 15c when you look at the temps. I use the same board with an e-6600 and the temps read 15 degrees colder than they should be. for instance my asus p5k deluxe read 4 degrees c warmer than my evap temp. where the p-35 lp-ut reads 11 degrees colder than the evap. which is impossible.
DFI LP LT X-38 T2R
Thermaltake 1KW Psu
hmm
you r talking about e6600 and there is differences with my go rev e6850
and what I know theres 15c difference with the ex models of conroe
I'm talking about g0 rev's
so please give me any temp reading prog , we can compare our results
or I can compare with your program and coretemp (tjunction 100 )
thanks for your help
just hanging on
lol
that's what I want to mean
thanx a lot @KTE
just hanging on
DFI LP LT X-38 T2R
Thermaltake 1KW Psu
I understand, but AuriL your temps are still very... unexplainable though.
