Each pump is a high capacity chemical pump. The Condenser will utilize a Little Giant 3-MD-HC Pump that is good for up to 750GPH. The Chilled side will be powered by a powerful TE-5.5MD-HC capable of up to 1200GPH.
The Smaller pump doesn't have a loud motor, and most of the noise comes from the cooling fans for the motor. The 5.5 makes a consistent whine that is less noticeable when it actually is pumping water. But like the other, its fan makes considerable noise. However, in the enclosure, most of that sound will be kept to a minimum.
