Results 1 to 6 of 6
Thread: 50W enough for GPU?
    May 2003
    Belgium/Brasschaat
    50W enough for GPU?
    Hiya,
    I was wondering if a 50W pelt for GPU is enough for 24/7 use?
    and offcourse high overclocks?
    GreeTZ
    Xtreme X.I.P.
    Nov 2002
    Shipai
    what card?
    is it a 50W tec or will you use an 80W tec and run it @50W?
    50W actual tec cooling power would be enough for:
    8500/9100 works good
    9000/9200 works good
    geforce4 4200/4400/4600 works ok
    9500np/p works ok
    9700np/p maybe... 9800pro needs more i think
    CCW
    Guest
    Majormav uses a 156watt pelt on his 9800Pro I do believe.
    Craig
    May 2003
    Belgium/Brasschaat
    its a 9800Pro
    but is it hard to change te pelt?? don't have much expirience with pelts thats why I buy a swiftech because everything comes in the box
    Banned
    Dec 2002
    it has not yet verified.......
    i change pelt on mine, just takes some modding my swiftech 80watt pelt block. also needed to clean out and re-apply thermal material.
    in order to get descent overclock performance on your R9800, you need more than 50watt pelt. 80watt would be the minimum.
    Jul 2003
    I just change out the 80watt in the swifty for a 172 watt. Just got a gasket kit and it was no problem.
    Abit IC7 * 3.0c @ 4.095Ghz
    ATI 9800 Pro
    VapoChill 404
    Corsair pc3500
    3dMark01=25108-
    3dMark03= 7958-
    AM3= 62,476 Team 3DMaxx.net
