+ Reply to Thread
Results 1 to 2 of 2
Thread: Budget E2180 build questions
    Aug 2007
    Toon
    6
    I'm building two near identical systems on a low budget, aiming to keep below £150 (~$300) per system. Both the systems are CPU/Mobo/RAM upgrades of SoA Athlon based systems and will be primarily Office/Internet PCs rather than gaming rigs so onboard GPU is fine.
    I've settled on the E2180 (£54) as the CPU and 2GB (2x1GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800) 4-4-4-12 (£36)for the memory. Any better options?
    What OC can I expect from the E2180 on the stock cooler?
    Would it be worth trading off an E2140 (£42)/E2160 (£48) against a better cooler (Arctic Cooling Freezer 7 Pro £13) to acheive a higher OC? I am not 100% sure this will fit in one of the cases.
    How likely is it that I'll need new PSUs, if so what wattage?
    And most importantly, which motherboard to get?
    I'm currently looking at the Asus P5KPL-VM, iG31 uATX, On Board VGA. On board graphics is preferred but I would be willing to trade this off for a higher CPU OC and a ATI 2400/NV 8400 so long as I can stay in budget.
    http://i26.tinypic.com/2s7ared.jpg
    Intel C2 Q6600 G0 @ 3.6GHz
    ASUS Ragimus Formula SE
    HD4870x2 2048MB Gainward Rampage700 Golden Sample Goes Like Hell @ 775/1100
    4GB GSkill Pi 6400
    Antec 850W TruePower Quattro
    50" Full HD PDP
    Red Cosmos 1000
    Nov 2007
    0
    I would go for E2140 or E2160, from what I've seen they tend to do better then E2180.. i've got a E2160 L2 @ 3.2Ghz, I can get it at 3.3GHZ without going over 1.5V
    GIGABYTE H55M-USB3 | INTEL CORE i3 540 @ 4.4GHZ (1.40V) | CORSAIR XMS3 DDR3 2X2GB DDR3-1536 CL 8-8-8-20 | XFX ATI RADEON HD 5770 1GB GDDR5 | SEAGATE BARRACUDA 1TB 32MB CACHE | SAMSUNG DVDR/RW/DL | OCZ STEALTHXSTREAM 500W 80PLUS | FRACTAL DESIGN DEFINE R3 SILVER | COOLERMASTER HYPER 212 PLUS | LOGITECH EX 100 | DELL 2405FPW 24" MONITOR 1920X1200 | WINDOWS 7 64-BIT | MAC OSX 10.6.5
+ Reply to Thread
