I'm using a back plate, it was okay for half hour whilest i had dinner then i come back and oh dear!!
Not happy! D-tek suck , the ''chroming'' is all peeling off as well!!!
What did you use to tighten that so much to bend the mounting plate?
Im assuming you had to bend the plate to make it peel like that, or you just got a dud.
lame.
New work-in-progress - watercooled dual-rad Lian-Li A05:
http://www.xtremesystems.org/forums/...d.php?t=156162
Opteron 175 @ 3.0GHz
273x11
Who did the chroming on that, and what the hell did you do to it?
Finger to tigthen it, exactly like the manual said and all out the box from new!
It'll be going back as its not worth anything at all.
I think you got a dud. My plate on my fuzion is bent from the force and it isn't peeled at all.
The Cardboard Master Crunch with us, the XS WCG team
Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
Damn! It's your fault though, didn't you know you need to run corrosion inhibitor? ROFL
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
"Artificial intelligence is no match for natural stupidity."
wow... how the hell did it start to peel off like that? just poor quality control, get a replacement.
E4400 @ 3100Mhz 1.375v // P965 DS3 rev3.3 // 4GB D9GMH
EVGA 8800GT // Antec P182 Gun Metal // Corsair HX520W
Dell E172FP 17" TFT // Logitech MX1000 // Saitek Eclipse KB
Apogee GT // Maze 4 // Laing D5 // Swiftech MCR320-QP
mATX soon...
My Fuzion plate isn't even chrome! rofl
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
Wow, that's probably a dud... my mounting plate is fine!
Definately a bad chroming job. If you know a local chroming shop you can have them rechrome the mounting plate. Another good option is to have it replaced.
I still don't know/understand why my Fuzion isn't chrome...
That's really strange, Nick. Mine is...
Mine isnt chrome either... D-Tek at first did NOT chrome the brackets.
XSWCG Disclaimer:
We are not responsible for the large sums of money that you WILL want to spend to upgrade and add additional equipment. This is an addiction and the forum takes no responsibility morally or financially for the equipment and therapy cost. Thank you and have a great day.
Sigmund Freud said... "Failure to CRUNCH is a sign of Sexual Inadequacies".
My is chrome but it did not peel off.
Mine isn't chromed.
"Finger tight" is subjective at best. It's like me telling some newb, who's never heard one, how loud a D12SM-12 is over the net.
I just want to know if we're going to see Pete constantly trash the FuZioN from now on like dnottis and NickS continually trash the DDC.
Circles SucQ!
Hell mine isn't chromed either.... I want one so it can peel off!
mine is carbon fiber
CPU Q6600 @ 3.15Ghz D-tek CPU Block
GIGABYTE GA-EP45-UD3R 350Mhz FSB
RAM G.SKILL F2-8500CL5D-2GBHK DDR2 1066
GPU Nvidia 8800GT MCW-60 700Mhz Core 1.0 GHz Mem
PSU Cooler Master realPower 550W
Storage 3 500 GB WD Caviar SE16 in RAID 0 + 300gb WD
Misc. CM stacker STC-T01 w/ Cross-flow fan, 2 MCR-320 Rads, DCC 355 W/ Petras Top, 12 YateLoon D12SL-12, ~12ft Tygon 9/16 ID tubing
Crunching for [XS]
They used to be made from 2B finish stainless, they are now made from chrome plated mild steel because it is signifigantly cheaper.
The older stainless ones are far superior, although maybe not as much "bling".
