+ Reply to Thread
Results 1 to 7 of 7
Thread: Crucial Ballistix Tracer Question
    Xtreme Member Techie's Avatar
    Mar 2007
    Belgium
    0
    Hi all,
    I got a pair of Crucial Ballistix Tracer (2 x 1 gb). This is the PC8500 version. When I open cpu-z and click on the memory tab, cpu-z says I got PC6400 memory. At this moment, I want to add 2 x 1 gb of memory, because I want to run vista the smooth way. Can i buy the PC6400 version of these crucials, or should i buy the PC8500 version? The difference in price is 20€ (belgium). In other words: is there any difference between the PC6400 or the PC8500 or can the PC6400 run at PC8500 speeds without problems?
    Thanks in advance,
    Techie
    * Intel Core2Quad Q6600-B3 @ 3,2Ghz | Corsair HX620
    * Asus P5P43TD
    * Corsair Dominator 2x2GB DDR3-1600
    * Nvidia GeForce 8800GTS 640MB (heavily OC'ed)
    (will be replaced by ATi Radeon 6950 soon)
    * 2 x 250gb Western Digital Caviar + 2 TB Samsung External
    (OCZ Vertex 2 90Gb SSD soon)
    Xtreme Mentor
    May 2007
    0
    They're binned versions of the 6400 IC's that's why SPD still reads those values. EPP profiles should read 533MHz 5-5-5-15 2.2V, I have the same ones here. Mine do DDR2-1200 4-4-4-4 2.2V, DDR2-1350 at 5-5-5-15 at 2.2V and 1460 5-5-5-8 should easily be possible at higher volts, but it's pointless. I've messed once at 2.35V at 1450 5-6-6-25 and I didn't even try lower timings. I won't risk them at the slightest.
    I run them at DDR2-1000/DDR2-1066 5-5-5-15 at 2V usually or DDR2-800 4-4-4-4 1T at 1.9V.
    I've not seen a D9 Crucial PC2-6400 that can't run DDR2-1066 at the same voltage and lower. If I were you, I'd get the PC2-6400 version of Crucial D9 RAM. Beware though, I've had a pair die before with 2.25V continuous use after 4 weeks.
    Xtreme Addict ineedaname's Avatar
    May 2006
    Canada
    0
    You spoke too soon KTE
    cuz i actually have a pair of 6400's that can't do 1066 at the same voltage.
    I got some pretty crappy sticks that won't go over 1000 at 2.2v
    CPU: Q6600 @ 3.6ghz G0 Week 37B
    Mobo: Asus P5k Deluxe
    Cooler: TRUE 120 (150cfm Delta)
    2xHR-05
    2xHR-09
    Mem: G.Skill 4x1Gb 6400HZ
    Vid: HIS 4850
    HDD: 80Gb 16mb Cache Raptor
    500Gb 7200.11 Seagate
    PSU: Enermax Noisetaker 600w
    Case: Thermaltake Armor (4x120mm 104CFM Panaflo)
    3dmark06: 16k
    Xtreme Mentor
    May 2007
    0
    Well I've never seen it though
    It's good to know the info ineedaname. Never known of a D9 before today which couldn't reach those MHz. Sorry about that mate.
    Dave's Mentor! zsamz_'s Avatar
    May 2007
    montreal
    4
    lol i got a pair of 6400 tracers that cant do 1100 @ 2.6v lmao
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
    Xtreme Cruncher S1mon-'s Avatar
    Dec 2006
    Montreal, Qc
    0
    My Ballistix 8500 do 600MHz (DDR2-1200) 5-5-4-9 @ 2,22V
    Main system:
    Q6600 G0 L737B 3,8GHz
    Maximus Formula X38
    Ballistix PC2-8500 2x1GB
    XFX 8800GT XT
    Corsair HX620
    X-Fi Platinum
    150GB Raptor (Dual Boot) /2x 250GB WD Caviar (Apps)
    Lian-Li V2000B Plus II
    School: MacBook
    Studying in: Pharmacy
    Where: University of Montreal
    May 2007
    montreal
    4
    Quote Originally Posted by S1mon- View Post
    so do mine lol
    i like 1080 5-4-4-9 2.13v
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
+ Reply to Thread
