+ Reply to Thread
Results 1 to 17 of 17
Thread: Copper Stock
    Jun 2007
    0
    Copper Stock
    Where do you guys get the copper stock for making your pots? I have looked for copper but its like 500 bucks for 3.5" wide at a foot long length. I guess before I make assumptions, I should ask how much these things usually sell for. Im not wanting to buy one, so admins leave this alone. I just want to know if money is lost in making and then selling these things, because copper looked expensive as hell to me.
    Thanks,
    Alphachicken
    Jun 2007
    0
    No one can help me find a place to get copper and advise on what pricing should be? (23 views)
    Xtreme Enthusiast DetroitAC's Avatar
    Jun 2006
    Northville, Michigan
    2
    It's current price is between 3.60 per in^3 and 2.80 per in^3. Larger cross sections are cheaper, and longer bars are cheaper so a 3.5" diameter bar 12" long should cost you $415 if we figure it is @3.60/in^3.
    I don't know of a place that sells 3.5" bar 1ft long at reasonable prices, so I can believe that you've found a place that has a high markup. That's the metals biz, unless you can buy large qty you get to make their Corvette payment for that month.
    You see what you did there? You got between me and the coffee, now this creates a SITUATION!
    Xtreme Guru Solarfall's Avatar
    Jun 2006
    Finland, joensuu
    0
    Evga X58 sli under cascade
    http://www.xtremesystems.org/forums/...d.php?t=219788
    Evga X58 Sli ultimate overclocking/ overview/ discussion thread
    http://www.xtremesystems.org/forums/...d.php?t=221082
    proud owner of E8600 Q822A435
    Xtreme Addict Fujimitsu's Avatar
    Aug 2007
    Cumming, IA
    0
    Quote Originally Posted by Solarfall View Post
    XBOX Gamertag:Fujimitsu - I'm lonely, be my friend!
    Banned
    Aug 2007
    0
    Quote Originally Posted by AlphaChicken View Post
    Thanks,
    Alphachicken
    where do you live?
    Perhaps it's better to send someone a drawing to make a pot for ya?
    Pots can be had for around 100$ these days
    Xtreme Member Sweeper's Avatar
    Dec 2005
    Jacksonville, FL
    0
    If your looking for round solid copper bar....try onlinemetals.com or if your looking for copper pipe....I know a good source.
    Xtreme Mentor teyber's Avatar
    Feb 2007
    Victoria, British Colombia
    0
    yeah, you can get some 2.5" copper, 2" for like 40$, and then some aluminum tubing and then machine it.
    solarfall, how will i ever repay you...
    mentally confused and prone to wandering
    Xtreme Enthusiast The_Beast's Avatar
    Jul 2007
    Wisconsin
    0
    you could buy 12; 3.5"x1" and JB weld them together
    - Gigabyte DS3L P35 - C2Q Q6600 - Antec NSS NSK4480B - Corsair XMS2 2Gb - Kingston Hyperx 4Gb - Sapphire 2600 XT - 2 Samsung F3 2TB - 2 WD Black 750 GB - 2 WD Black 1TB - Seagate 320 GB - Dell UltraSharp U2410 - Logitech Z4 - Corsair 750HX - Windows 7 Pro and XP Pro Dual Boot -
    Feb 2007
    0
    Quote Originally Posted by The_Beast View Post
    i would recomend brazing
    Jun 2007
    0
    Hmm. Its not that i want to just make one pot. I was thinking about how you guys are able to sell a solid copper pot for only 100 bucks.
    Turkey Man T_M's Avatar
    Mar 2005
    Jakarta (ex-Australia)
    4
    Alpha, i would presume that different countries have different pricing on stock.
    For example eastern european countries lately are selling reasonably cheap pots.
    Another thing that would help lower the price is to buy in volume, or have the machinist buy for you (since they are more likely to want volume).
    All this is just my thoughts, ive never actually bought my own stock before.
    Aug 2007
    Cumming, IA
    0
    Above poster is right I believe, metal seems to be cheap in eastern europe. Although I've never seen solid copper anywhere near $100, that's about what you'd pay for alu...
    Other than that, buddy up with a machinist who'll sell to you at cost, that's probably the cheapest you'll find short of buying used copper parts. If you're looking at a two-piece design you could design the base and just attach it to a 2" section of pipe.
    As far as JB weld, it should work... if not soldering is also an option. Brazing isn't necessary under these pressures, all you have to worry about is using something that stands the temperatures.. so many epoxies/glues would be OK.
    Aug 2006
    Stockholm, Sweden
    0
    well.. first off, as a private person you don't get much discount, if any compare to a company which can have everything from 50% to 80% discount... the companys doesn't want to sell in small quantitys.
    1' = 12", 4" (100mm) is enough for a cpu pot to be honest. your 500bucks is now 167usd for each pot in copper.
    Feb 2007
    0
    good point tim, another thing to mention: is it really necesarry to have it be 3.5" wide? i mean the distance between holes in a lga775 board is 2.5" i believe... so wouldn't 2.25" be better for mounting?
    Reed
    Xtreme Addict Duniek's Avatar
    May 2005
    POLAND/Cracow
    0
    Quote Originally Posted by teyber View Post
    Reed
    lga has 72x72mm holes dimension so 4" from center on one hole in slant to second center of hole
    so you can make pot with max 97,82mm (3.85") diameter if you want use m4 screws
    Aug 2006
    Stockholm, Sweden
    0
    72x72, thats correct phytagoras says, to get the diagonal take sqrt(a^2+b^2),
    sqrt(72^2+72^2)= 102mm -> 4inch
+ Reply to Thread
