Results 1 to 19 of 19
Thread: Coolermaster Stacker 830 EVO - seeing the light
    I am Xtreme
    Aug 2003
    I've always been opposed to large cases. Just never liked them. I also never wanted to spend lots of money on a case. Last year, as I'm sure some of you remember, I cheaped out and got an Antec 900 instead of the Lian Li V1000 I wanted. The results were... not pleasant to say the least. I had wanted a stacker 830/2 for a while so when I saw the stacker for 140 AR at Newegg, I bit.
    bottom vent
    I'm hoping that's sufficient case cooling...
    compared to antec 900... nice and big.
    Motherboard tray, very nice. Makes everything easy! Note the holes for external watercooling Can also be flipped in seconds for BTX operation.
    4x front USB, front firewire, front AC97/HD audio connectors, standard power/reset switches and LED cables
    Top exhaust with filtered 120mm fan mount. Can also be replaced with an LED lit hard drive tray if you have one of those fancy raptor X drives
    ANTEC TAKE NOTES SECTION
    FOUR (not 3, Antec) in 3 hard drive adapter with a QUIET blue LED fan
    Side walls of the adapter are removable so that installing the drives is not a nightmare. They screw in easily. Side panels are mounted to blue rubber sound dampeners, which actually work pretty well. My 2x Raptors no longer sound like grinding death!
    RIDIN RIMZ!
    PSU bracket is a breeze to install
    Two aluminum "doors" of sorts cover the latches for the vents and are flush with the front when closed (if that makes any sense)
    My current setup The Coolermaster PSU I purchased with the case will not work with my MSI board so I have the Enermax on the floor until a real motherboard arrives. Watercooling is also external because it will not fit with a sound card installed.
    Overall, working with the case was VERY easy. Everything except the motherboard, PSU, and hard drives are tool-less installs.
    Front door is made of nice thick aluminum (unlike the cheap plastic in many cases) and shuts magnetically
    Side fan bracket accepts FOUR 80mm, 92mm, 120mm, or 140mm fans. Snap in brackets with dust filters for 120mm fans come stock. Latches to/from the case extremely easily
    Side panels are held into place with a very simple lock/unlock tab at the top rear next to the PSU. However, they are not 100% stuck in place and you can move them a slight bit.
    Mobo tray once again has one tab and two sliding clamps
    The mobo tray, side fan bracket, and front door can all be quickly reversed/flipped to allow for a BTX installation.
    PCI slots use thumb screws
    5.25" devices lock into place with plastic locks on both sides of the bay. It can also hold smaller 5.25" devices like fan controllers in place without them flying back into the case when touched. Only downside is that CD drives are not 100% stable and they do move back and forth a slight bit in the bays. Fortunately, Coolermaster left openings for screws as well if you wish to use them.
    The wheels are a nice addition, seeing as the case weighs a ton with everything installed. Two of them lock so the case doesn't roll all over when you touch it. Be careful when installing them as the screws strip very easily. There are also two recessed handles at the top of the case that can be used for transportation. I'm not quite sure how much I would trust them to carry a full case though, the top panel is secured to the frame with four small screws only.
    Every part of the case is made of thick, high quality aluminum. Easily the heaviest aluminum case I've ever had. The build quality, however, is top notch. It's 110% worth the added weight. The exterior of the case is nothing short of gorgeous as well.
    The two stock fans are not loud at all and the LED intake fan is not overly bright. A well balanced LED fan
    With most things, you get what you pay for. Cases are no exception. After 7 years of messing around with cheap cases, I'm glad I've moved on. After spending a day with this case I would be more than willing to pay the full ~200 dollar MSRP for it. The difference in ease of install in a large, well built case and a smaller, budget case is night and day.
    PROS
    Can run ATX and BTX
    Mostly tool-less
    cools extremely well
    well built
    easy and quick to install
    removable mobo tray
    up to SEVEN fans (4 side, 1 front, 1 rear, 1 top)
    bottom vent for more ventilation or easy watercooling install
    external watercooling pass through holes
    high quality all aluminum construction
    Fan filters on the side and top fans
    Quiet 4 in 3 HDD adapter
    wheels included
    handles on the top of the case
    CONS
    Tool-less installs could be a bit better. The 5.25" locks and side panel locks could be a bit more secure. Doesn't bother me at all but some people might not like how they can move a little.
    There is not enough room under the motherboard to fit a radiator + fans on the bottom vent with a sound card or SLI installed. In BTX form however, it should fit fine.
    The external watercooling holes are not wide enough to fit 7/16" or 1/2" tubing through without the rubber protectors coming off.
    the rear side panel sits right on the back of the case, preventing you from routing the PSU wires behind the mobo tray for clean wiring.
    Overall I'd give the Coolermaster Stacker 830 EVO a 9.5/10
    I have a Thermalright Ultra 120 Extreme heatsink and an Abit IP35 Pro motherboard in the mail so I'll get some pics of a proper finished install up ASAP!
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    i would want one but it's 250$+ here.
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
    I am Xtreme
    Oct 2005
    Grande Prairie, AB, CAN
    You can fit the power cables from the PSU on the other side of the motherboard tray, it just is a really tight fit
    Here is an old setup,
    even with all that I could still close the door.
    all outta gum
    Dec 2006
    Poland
    I am thinking of getting a Stacker 832, but one thing buggers me: the power button. Don't you think it's of rather poor quality? or maybe that Stacker I saw had something broken?
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Jun 2006
    Portugal
    My future case, no doubt about it...the only thing that bothers me is the price (around 370$ where i live)
    I can only blame th f taxes, government, whatever...
    Sorry for my poor english.
    Dec 2004
    Bucharest, Romania
    Love it myself. It's around 330$ here. I'm seriously thinking of ordering it from ebay or somewhere, just hope that shipping won't kill me with all that weight.
    Intel i7 920 d0 @ 4410MHz @ 1.36v :: Prolimatech Mega Shadow :: Gigabyte EX58-UD5 F9K :: 6GB Mushkin XP3-15000 :: HIS 5870 :: Corsair 1000W :: HannsG 27.5" :: Lian Li V1010B
    Sep 2007
    Bolingbrook
    Question
    Just picked this case up today and have a few questions:
    @Lowfat, did you drill holes to achieve those wire management...coz mine didn't come with holes on the mobo tray.
    ---also, what paint did you use for the inside; was it flat black? what brand and did you just spray it or sand it first?
    ---nevermind, just read the rest of your post...sweet deal for $75
    @afireinside, what brand of fan would you recommend for the top fan? I'm going for quite fan vs powerful fan.
    ---what model is that Enermax PSU? are the cables long enough?
    ---is there a way to mount the HD backwards to hide all the wires?
    ---almost a month now, any regrets or suggestions for new folks getting this case?
    thanks to everyone
    Win7Pro 32-bit/ ABIT IP35 Pro v1.1 BIOS v.16beta09/ Intel C2D E8400 Batch Q748A223 /Xigmatek HDT-RS1283/ 4GB Corsair CM2X2048-6400C5DHX 5-5-5-18 1.80V ver4.1/ CORSAIR 850AX/ CM Stacker 830SE/ ZALMAN ZM-F3RL 120mm Red LED/120mm Yate Loon D12SL-12 Red LED/ Creative Labs Fatal1ty ProGamer/ MSI R7870/ Dell UltraSharp 2407FPW-HC...new FPS: Groundbranch.com/
    Ace's 40mm fan solution...be my buddy
    Jan 2007
    afireinside,
    can you please post some more pictures on the tool less installs. looking to get one myself but not a big fan of tool less installs. thanks.
    May 2007
    Looks like these SE`s, they made some nice minor changes, a + for the watercooling holes, why didnt they consider it earlier, and I like the Mobo tray.
    DFI Lanparty LT X48-T2R
    Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
    eVGA 8800GTS (G92) 512MB {stock}
    Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
    Lian Li PC-V1000 {modded}
    Corsair HX 620W
    Creative X-FI ExtremeMusic
    Western Digital Raptor X 150GB
    Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
    Aug 2006
    The Netherlands, Friesland
    @M2ck,
    What happened to the lian-li?
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
    Xtreme Cruncher
    Dec 2002
    NW Ohio
    AFI,
    Your such a traitor.
    J/K nice case bud. Remember our convo a while back when we were talking about cases and how we wouldn't spend that much money? I picked up the CM690 and LOVE IT. It's a $150 case that only costs ~$60.
    Donate to XtremeSystems!
    Workstation: Intel Core i7 4770, Asus Maximus VI Gene, 32GB Corsair Dominator Platinum DDR3-1866, eVGA SC GTX Titan, 256GB Crucial M4, Corsair HX850, Corsair H100i. Corsair Carbide 350D
    Fileserver: 2x AMD Opteron 2425HE, Supermicro H8DME-2, 24GB DDR2-667, Supermicro 846TQ 24bay Chassis, Redundant 920w, 256 Crucial M4 boot, 20TB Storage
    Notebook Asus Zenbook UX32VD-DH71, Intel Core i7 3517u, 10GB DDR3-1600, 256GB Crucial M4, Geforce GT 620M
    I am Xtreme
    Aug 2003
    Quote Originally Posted by WesM63 View Post
    AFI,
    Haha... yeah. The price was right though. Couldn't help my self
    Quote Originally Posted by timber715 View Post
    afireinside,
    What else do you want to see? PCI = thumb screws, CD drives = slide locks, panels/mobo tray = tab locks
    Yateloons FTW!
    It's an Enermax Liberty 500W PSU. Cables are plenty long.
    I'm sure you could mount the HDDs backwards but it would be a pain to run the PSU wires to them.
    No regrets so far.
    Current:
    Actually... I got another one for my brothers computer build. They shipped me a regular evo non SE. The finish on his panels feels MUCH smoother than mine Maybe mine is just a defect.
    Xtreme Cruncher
    Dec 2002
    NW Ohio
    Looking good bud!
    3870's?
    May 2007
    Quote Originally Posted by ownage View Post
    @M2ck,
    got it modded @ aquatuning.de , should be here soon, the Evo i got like a year from my old AMD X2 build
    Corsair HX 620W
    I am Xtreme
    Aug 2003
    Looking good bud!
    3870's?
    you bet!
    Aug 2006
    Quote Originally Posted by mc2k View Post
    Send those pictures when its done , or post it here at XS!
    @AFI
    830 EVO and hd3870 xfire is a perfect match. Looks damn nice.
    >i5-3570K
    >Asus GTX 670 Mini
    >CM Silent Pro M700
    Jan 2007
    yes, if you insist...
  18. #18
    I am Xtreme
    Oct 2005
    Quote Originally Posted by Cpl Ledanek View Post
    thanks to everyone
    Yes i drilled the holes. It was pretty easy though. Just a simple hole saw with a 1.5" saw blade.
    Yes you can mount the hard drives backwards. That is what I did with mine.
    I still love my Stacker 830 after ~ 6 months. Only thing I disliked about it was how easy the exterior gets damaged. I don't believe they are anodized at all. This is why I got mine painted.
  19. #19
    Dec 2005
    Cinci OH
    I have the original version of this case. I love it. I had to drill my own holes in the back for water cooling
    Did you also drill the small holes in the mobo tray? Looks good.
    I also like the mesh at the bottom of the case. I wish mine had that.
    Intel i7 3770k
    ASUS Z87-Pro
    Corsair Vengeance 4x 4GB
    Corsair 1000HX
    ASUS GTX 780
    Samsung 840 EVO 500GB SSD
    Corsair H100i H20 Cooling
    SB X-Fi Titanium Fatal1ty
