I have a G0 Q6600 and the first 2 cores run 5 to 10 degrees warmer than cores 3 & 4.
I realize that all 4 cores will never all run at the exact same temp, but this seems like an awfully large difference.
Thanks!
Thanks!
Ah OK, thank you.
I have a Zalman 9700, so no crappy push down plastic here
My coretemp and everest etc readings show similar results even though the temps are wrong because I'm on phase and it can't read that low. Sometimes this can be caused by a crooked mount, but I have checked 3 times to see that mine was flat. I've seen that some are closer than others. Check just to be sure, that you have full coverage on your sink.
{2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
In everest i get 52 to 60 under full load...i am concidering lapping my TT
CPU: i7 2600k @ 4.4Ghz GPU: GTX 560ti 2G SLI RAM: 16G Corsair Vengeance MOBO: P8Z68-V PRO GEN3 BOX: Cosmos S Cooling: Corsair H100 SSD: Corsair 120G ForceGT
