Has anyone checked or considered the impact of phase on an x38 NB yet? It has an IHS so the idea seems, at least mechanically, like a possibility.
[SIGPIC][/SIGPIC]
one person did it on here and said they where in the 630s fsb with it on the x38 and one unit on the cpu.
Silverstone FT02
Asus Maximus III Formula, Intel i7-875k, Corsair 4x2gb Dominator 1866mhz
SLI EVGA GTX 580s, PCI-E X-Fi Audio
2x WD Raptor 600gb sataIII Raid 0, 2x1tv WD SATA Black Raid1
Thermaltake W0133RU 1200W
Windows 7 Ultimate x64, Dell 2310 3d lcd
There are always gains to be made by chilling down components, just need to judge if it's worth the expense. I myself have a tiny single-stage that I'll be using on my incoming P35 to see if it'll help crack some records but for daily applications or even quick dice/single-stage benching it probably isn't worth it, a 40mm fan would be a better option.
So there is no Cold bug on it?
Question is more if they gained somthing from it
How boring! Please ban him to the Air Cooled section
But seriously: I think he´s right. Not EVERYTHING has to be cooled by phase-change. Even if you can push up the FSB more under phase-change, I don´t think it is worth the effort. As far as I know all the records have been made by LN CPU cooling and a nice fan on the NB.
Phase Change Building - made in Germany
Single Stages
Oven brazed Evaps
LianLi V2000 Drop-In Chiller
SC21 Single Stage
Honestly, if you are willing to go that far, might as well submerse whoe thing and cool all components of it till... say about -5c... caps don't like getting TOO cold.
(CPU & GPU already phased...)
Why don't you just make a simple alu pot (pipe with endcap) and throw dry ice in it?
maybe 15- 40fsb. youngpro has a unit with cpu/nb heads. I think he might start using it again more now his QX9650 has arrived.
Mines been okay, When i pulled stock cooling the IHS came off and everything was fine, no deaths or anything.
I cover the SMD's with some insualtion and refitted the ihs on but not stuck down.
I was bord was reason i fitted the SS to the NB. CPU was downfall at time
I mounted an old vapoSE on the NB of my maximus formula. gave me a 10mhz fsb boost, but the nb was only -5*C because of bad mounting. Colder might gain some more.
I dunno, -5c is really cold compared to the stock temps northbridges usually are at, I don't think you'd gain all that much more if you only gained 10 fsb, but good luck nonetheless
How about turning the old vapose into a chiller, as the maximus does have a waterblock, you could use that to cool the cpu, nb and gfx if you really wanted to
Insulating a chilled loop is a pain and having to insulate that stock maximus waterblock looks like a nightmare.
The stock NB is about as good as blowing out ya nose with it blocked up. It's really tight in there. I t also added 1psi to my loop presure
It shouldnt be worth putting more than water on the chipset, for any reason. Its been said and proven that its not the board that decides FSB, but the chip.
The best thing to do is just take that money into finding a chip with better FSB, but if you have a unit laying around, I cant see the harm
Uhmmm... there is something called... "dew" point. It's not necessarily freezing point of water.
My bet is on the coldbug. Tried phase on P965, couldnt run 470+ at 1066MHz CPU:FSB strap. Aircoold with 1.8V-1.9V i could run 500MHz+ at same strap. So cold bug definitely on P965. I have heard it is the same with P35, so it is quite obvious that X38 as the P35's derivate of somekind suffers the same.
EK Water Blocks R&D
ekwb.com
Hobby: Rotary SS bench unit (LPG/R-507) | -75°C Auto-cascade (R-600/R-290/R-744) | Plate HX water chiller (1kW cooling power) | My 2nd cascade MP14FB R-507/R-1150 | Mini cascade R-507/R-1150 | GPU single-stage | Mach I restoration mod -> -38°C @ 230W
Milestones: 7.12GHz P4 | 6.84GHz K10.5 | 6.45GHz Ci5 | 3.31GHz K7
3DMark2001SE -> Favourite Game!
While using phase on my GB-P35 board the NB gets pretty cold, at least the heatsink is cold. It seems like the cold from the cpu transfers trough the board to all the closest parts. Well, the heat transfers.
I benched once on a p5b dlx with DI on the NB and we managed to get sligtly higher clocks AFAIK, the most important thing we archived by using DI on NB was stability vs air on NB while overclocking with DI and LN2.
Hmmm has anyone displayed results with the x38 super cooled because I have posting issues when my x38 is really cold on a cold morning and im just water cooling my x38 and SS cooling my cpu...
Im not saying that it might not be something else but on those cold days it does take a bit of heating up before it will successfully boot with out a triple beep...
Never empower an idiot with a response....
http://en.wikipedia.org/wiki/Troll_%28Internet%29
Seller/Buyer Reputation:
Heatware: http://www.heatware.com/eval.php?id=50905
Ebay: {Family Account} Kasyg3 http://myworld.ebay.com/kasyg3/
Ebay: {My personal Account} Sdumper http://myworld.ebay.com/sdumper/
iTrader: http://www.blazingpc.com/forum/itrader.php?u=28
