Can anyone recommend a dust proof metal mesh to use for fan dust filters?
I am trying to customise the front panel of my lian-li PC-70
I dont suppose anyone knows somewhere i can buy different front panels for this case.
This might sound corny, but try stockings. I haven't tried it myself, but I've heard of a few who have.
yeah was thinking about that but this mesh might end up being visble thats the only thing
why dont u glue some black stockings between two layers of the metalmesh u want? it think this would look nice and clean
shear man
um... dont mean to nitpick but... my countless hours of workin in the family store fixin the stocking and pantyhoses just dont let it go by so easily... it's Sheer...
and it may work but you will also will have to clean it up pretty often...
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands in times challenge and controversy."
Dr. Martin Luther King Jr.
DIY: Self Clinching Nuts
Canon EOS 7D | Tokina 12-24mm f/4 | Canon EF 24-105 f/4 L | Canon EF 70-200 f/2.8 L IS Mk II | Canon EF 35mm f/1.4 L | Canon EF 400mm f/5.6 L | Canon EF 100-400mm f/4-5.6 L
what about trying an air filter for a home furnace. they are white though, which may be more visible. you shoudl be able to cut it into any shape you need.
i5 4690k @ stock on Apogee GTX
MB ????
RAM ???
HD6970 on mcw60
PA120.3
Custom Built Case
My Blog:
http://www.destructoid.com/blogs/Locke
yeah i think i like the black stocking idea though.
There is no such thing as dust proof. If you restrict the fan filters too much, the fan is going to get air from somewhere and that can result in sucking in unfiltered air from every crack imagineable.
I use the thin black fiberglass mesh that is used for mosquito netting for porches. It isn't very restrictive but keeps out the bulk of the junk. I only have to blow my system out about once a month.
Latest Project Log: Project Quintessence
1935 Zenith Radio Scratch Build
lint sheet from the dryer?
filter from an old air conditioner
i5 2500k @ 4.6ghz 1.335v [ASUS P8Z68 Deluxe]
8gb gskill ripjaws f3-12800cl8-8gbxm
600gb velociraptor + 1TB black
MSI N560GTX-TI Twin Frozr II + x-fi xtrememusic
corsair hx-620w + lian li pc201b + dell 2408fpw
d-tek fuzion1/ddc2 + petra top/thermochill pa120.3
two layer of stocking? lol
just make sure u dun stack them too close .. give them 2mm gap or so
there's a some paper filter maybe u can get some of this .. http://en.wikipedia.org/wiki/Air_filter
but blocking too much air can really stress up ur fans .. trouble is .. the fan itself gonna produce a handful of heat.
