+ Reply to Thread
Results 1 to 15 of 15
Thread: What RAM?!?
    Oct 2007
    0
    What RAM?!?
    Hey XS, I need help choosing between these 2 sets of ram.
    2x Crucial Ballistix PC2-6400 2GB 2X1GB DDR2-800 CL4-4-4-12 240PIN
    or
    OCZ Platinum XTC PC2-6400 4GB 2X2GB DDR2-800 CL5-4-4-15 DDR2 240PIN
    Price is nor problem, lets just focus on the performance. Which will be better to overclock? or will I even need to overclock? and is it recommended when overclocking cpu and gpu to overclock ram as well or can it be left stock? (ram overclocking confuses me lol, but if needed I'll learn)
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    20
    the crucial will destroy the ocz hands down its not even a contest
    3770k, M5E, kingston 2x4GB cfr
    samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
    Xtreme Addict Exahertz's Avatar
    Dec 2006
    Maryland
    0
    what about Corsair TWIN2X2048-6400C4? seems to match the crucial ballistix
    Current System Build
    Designaton:" Rad Hat "
    __________________
    • Mother Board, RAM and CPU:
      Mobo: Asus Maximus Formula (SE) BIOS 1207 | CPU: Intel q9650 @ 3.80GHz Vcore 1.272v | RAM: Crucial Ballistix Tracer PC2 8500 4x1GB
    • Graphics Processor:
      GPU: BFG 8800GTX | BFG 8600GT (Quad Monitor Setup)
    • Hard Drives:
      RAID: 2x 74GB Raptors on RAID 0 for OS Drives
    • Case and Power Supply:
      Case: Antec Case | PS: OCZ ProXstreame 1000W
    • Water Cooling:
      Pump: Swiftech MCP655-B | Rad: Dual Swiftech MCR320's | Fans: 6x Yate Loon D12SH-12's (W/ Variable RPM Rheostat) @ 88CFM Max Each - 528CFM Total!!!
    • (Water Blocks and Fittings):
      CPU: D-Tek Fusion Block | GPU: Danger Den Full Coverage 8800 Block | Mobo: EK's Mosfet, NorthBridge and SouthBridge Blocks
      Res: Swiftech Micro | Tee's: 4x MartinM's High Flow Copper Tee's | Elbow's: None | Y's: None
    Flow Order: >> Rad's 1 & 2 in parallel > Res > Pump > CPU > GPU > SB > NB > Mosfet 1 > Mosfet 2 >>
    Temperatures: CPU: 57°C Max, Running Prime95 | GPU: 58.3°C Max, Running 3Dmark | NorthBridge: Untested!
    Last Updated 11/11/09
    The Voice of Reason Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    0
    If price is not a problem, look at the Ballistix 8500 instead.
    Windows 7 + SSD:
    Mode: AHCI, default Microsoft driver or latest Intel RST
    Defrag: Off
    Hibernation: Off (use Sleep mode, recommend a UPS)
    Indexing: On (it only indexes a few locations, not your whole system unless you tell it to)
    Page File: On (set to the minimum of 16MB if you have a large amount of RAM, disabling not recommended)
    Prefetch: On
    Superfetch: On (RAM is always faster than an SSD - use it)
    System Restore: Off (with regular backups)
    Browser Cache: RAM Only, Disk Cache Off (How to with Chrome)
    Documents, Music, Pictures, Videos, Downloads to HDD (Public Libraries too, see above link about junctions)
    UAC: On!
    Jul 2007
    SF bay area, CA
    20
    Quote Originally Posted by Exahertz View Post
    those are promos or epidia crucial is still micron on all balistex models and on most if not all overall (they have some classic stuff with samsung but i think thats all of the non micron for ddr2 that they used)
    Xtreme Mentor
    Jul 2004
    Ontario
    0
    I would highly recommend the Ballistix Tracer PC2-8500 from Crucial if you can swing a few extra bucks.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
    Oct 2007
    0
    Crucial are great ram , period, and they are SO inexpensive now
    Xtreme Member Aleki's Avatar
    Sep 2007
    1
    get them while theyre cheap @ newegg! cant believe the 6400's are at 50 bucks a/r for 2gb!
    my mini-fridge
    MoBo: GA-EP45-UD3P | CPU: Q9550 3.6GHZ @ 1.216v | RAM: 4x1GB 900mhz @ 5-5-5-15 | GPU: GTX 460 900G/1800S/4400M | PSU: Corsair 750TX| HDD's: Seagate 320GB + 500GB, Samsung 1TB | Case: antec p180
    Dec 2006
    Maryland
    0
    Is GEIL any good?
    i found an 8GB GeIL Quad Kit of 4x2GB PC2 8500 for a decent price.
    timings are 5-5-5-15
    __________________
    • Hard Drives:
    • Water Cooling:
    Xtreme Member BigRigDriver's Avatar
    Jun 2006
    2
    Smile
    Try those http://www.newegg.com/Product/Produc...82E16820231145 they can do PC8500 on any platform & stay really cool.
    Oct 2007
    0
    can you help me, which set should i buy?
    4x1 gb kingmax 1066 ddr2 (5-5-5-15)
    or
    2x 2x1 Gb Geil Ultra 800 KIT (4-4-4-12)
    what is the max mhz with geil cl5?
    will the kingmax run at 800 cl4?
    Gigabyte P35-DQ6
    Intel Quad Core Q6600 @ 3.8 Ghz (1,36V) + D-tek Fuzion
    2*2Gb Super Talent DDR2
    Sapphire HD4870 512 MB
    RAID0 (3x HDD) + backup WD My Book
    Chieftec 750W
    Sep 2007
    1
    i'd say better off going with the 2x2 kit at the price the geil's are at now. 2 sticks draw less heat, and chipsets can overclock them easier than a set of four
    my mini-fridge
    Dec 2006
    Maryland
    0
    So from a gaming standpoint, would 8GB of GEIL (pc2 8500 5-5-5-15) ram be better than 4GB of Crucial Tracer (pc2 8500 5-5-5-15)?
    __________________
    • Hard Drives:
    • Water Cooling:
    Jul 2007
    SF bay area, CA
    20
    the crucial is better for gaming since its faster and u wont use over 4gb for a long time
    Dec 2006
    Maryland
    0
    yea i read some stuff about win xp supports a max of 4gb and that x64 even with 8gb isnt quite as fast when gaming. so i just purchased 2gb of crucial balistix tracer pc2 8500 for $99.00 and i hope to get some more soon.
    thanks again zanzabar
    __________________
    • Hard Drives:
    • Water Cooling:
+ Reply to Thread
