Results 1 to 9 of 9
Thread: Best mobo going if I was buying tomorrow?
    Nov 2002
    I'm looking for a board to overclock a 2.6C and be used for gaming exclusively. I'm going to run 24/7 at the oc'd speeds and will be using an slk-900 to start then water. These are the boards i've considered...
    abit ic7-g
    abit is7-g
    dfi 875pro lan party.
    At first i'm going to use Twinmos 3200 bh-5 in it, then either duel 3700/4000 gold.
    Please list other options you think I should consider
    http://service.futuremark.com/compare?2k1=6646300
    http://service.futuremark.com/compare?pcm=1361699
    http://service.futuremark.com/compare?2k3=921862
    2.8E/Abit IC7-G/2x512 Corsair TwinX4000-Pro/Sapphire 9800XT 256/36 WD Raptor/Logitech Z-560/Viewsonic P95F+B
    Dec 2002
    30N|95W
    probably the p4c800 or ic7-max3 which will be on the market soon
    Nov 2002
    thx for the reply but like I said "...if I was buying tomorrow". I also live in Canada so the max-3 won't be available for a good month yet here. Is the asus that much better to the ic7-g? I'm kinda partial to the abit because of the looks with the black pcb.
    Aug 2002
    try considering: epox 4pca3+ rev 1.2 or wait for rev 2.0
    Motherboard: ABIT AW9D MAX SLI LGA775+ CPU: Intel Core 2 Duo E6600 LGA775 2.4GHz CPU Cooling: Scythe Infinity
    Memory: OCZ DDR2 PC2-6400 800MHz Special Ops Edition Urban Elite Hard Drive: Seagate 7200.10 320GB SATAII 7200RPM 16MB Cache
    Graphics Card: Sapphire X1950 XTX 512MB Crossfire Master Edition GDDR4 PSU: Coolermaster eXtreme Power 650W
    Case: Antec 900 Operating System: Windows Vista Ultimate Monitor: DELL - 21" TFT
    OC: 3.6GHz - 400FSB - Stable
    CCW
    Guest
    Gooch informed me that the Asus is the better performer. Also, wasnt the IC7-G Max3 released friday?
    Craig
    Feb 2003
    Northville,Mi
    Right now the Asus P4C800-E, but if it were me , I'd wait
    for the Max III.
    P4C800-E Deluxe
    P4 3.0c 30 capper @
    280x15,5:4;4200MHz
    2x512 Zeus BH5
    Radeon 9800 Pro
    2 Raptors,raid 0
    Prometeia Cooled
    I Never Sleep
    Banned
    Nov 2002
    I would go for the Asus P4C800-E
    Dec 2002
    30N|95W
    it was released, but you cant find it for retail yet. as of now, the p4c800 is the leader.
    Nov 2002
    are the IC7-G and DFI 875pro that far off?
