+ Reply to Thread
Results 1 to 5 of 5
Thread: Would GB 3D Galaxy 2 perform better than Ultra 120 eXtreme ?
    Aug 2006
    Sydney, Australia
    0
    hi guys
    would Gigabyte 3D Galaxy II liquid kit be better cooler than Thermalright Ultra 120 eXtreme ?
    I would use Noctua Fan on either as silence is crucial.
    CPU would be mild overclocked to 3.2Ghz or so ... at 1.35V
    i7 920, EX58-UD5, 6GB Corsair 1600Mhz, 8344ELP + 4x146GB SAS, 2x640GB, 27" DELL, 4870, P182 liquid cooled, Antec Quattro 1kW, X-Fi Prelude + Z5500, Razer Mamba, G15
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    Generally the rule-of-thumb for water is to get good water or just get a high-end air cooler. I don't think the galaxy 2 is considered good water.
    If you plan on using the straight-blade noctua fan that is going to hold you back by quite a bit. They have practically no pressure to push any air through any sort of restriction. A better route fan-wise would be a low speed yate or a Scythe s-flex or something like that (undervolted if necessary) to have enough pressure to push the air through.
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    Xtreme Mentor Nanometer's Avatar
    May 2005
    Westlake Village, West Hills
    4
    Can be done with a good air cooler. Like said. No point to buy that garbage. If you don't know enough about water cooling to make your own loop, then you probably shouldn't be buying one of these crapola prebuilt stuff. Do a little research into water cooling and you will be rewarded
    PC Lab Qmicra V2 Case SFFi7 950 4.4GHz 200 x 22 1.36 volts
    Cooled by Swiftech GTZ - CPX-Pro - MCR420+MCR320+MCR220 | Completely Silent loads at 62c
    GTX 470 EVGA SuperClocked Plain stock
    12 Gigs OCZ Reaper DDR3 1600MHz) 8-8-8-24
    ASUS Rampage Gene II |Four OCZ Vertex 2 in RAID-0(60Gig x 4) | WD 2000Gig Storage
    Theater ::: Panasonic G20 50" Plasma | Onkyo SC5508 Processor | Emotiva XPA-5 and XPA-2 | CSi A6 Center| 2 x Polk RTi A9 Front Towers| 2 x Klipsch RW-12d
    Lian-LI HTPC | Panasonic Blu Ray 655k| APC AV J10BLK Conditioner |
    Banned
    Jun 2006
    in a Red Rage D....
    0
    bulky and quite fragile is the word for that galaxy... cpu block = fragile in motion, pump reservor assemble = to bulky, blocks of other goodies worth looking at...
    stick with ultra 120 xtreme...
    Xtreme Mentor
    Nov 2004
    Elma, NY
    0
    junk.
    i7-2600k @ 4.8Ghz 1.38v L044A892
    ASUS P8P67 LGA
    16GB G.Skill Rip Jaws DDR3 1600Mhz Memory
    1/2" ID Masterkleer, Swiftech MCP-655, Thermochill PA120.3 Rad, XSPC Rasa, MCW-60
    Cooler Master UCP 1100 Watt PSU
    GTX 680 1300/7000
    Lian Li PC V-2000
+ Reply to Thread
