X
    Subscribe to New Ads!
    Receive weekly ads in your inbox!
View Poll Results: What will happen when i turn the key?
Voters
14. You may not vote on this poll
  • Fires up, runs, back to normal
    6 42.86%
  • Doesn't work, wiring harness gone wrong
    2 14.29%
  • Horrible Fireball, Car, Garage & Owner incinerated
    2 14.29%
  • Blows the headgasket immediately, leaks oil, wets itself
    4 28.57%
Page 1 of 12 123411 ... LastLast
Results 1 to 25 of 297
Thread: My 1991 Toyota Supra
    Xtreme Enthusiast Kai Robinson's Avatar
    Oct 2007
    East Sussex
    Cool My 1991 Toyota Supra
    Behold ladles and jellybeans - my soon-to-be-17 year old Toyota Supra!
    After giving up on most cars made past 1995 and not wishing to have my performance options spoiled by emissions legislation in the UK (no cars built/registered prior to August 1992 need to have a Catastrophic Converter (yes, that was a deliberate pun!)), i decided to go for something quintessentially 80's in style and feel....you have to admit - pop-up headlamps are very cool
    I always liked these Supra's, far more elegant than the loud and brash jellybean Mk4's (only good thing about them were the mechanicals, the bodystyling and interior were 'meh...').
    It's built for going round these things in Europe and Japan called 'corners' and while its ultimately a GT/Cruiser, dont let it fool you, it'll give pretty much anything a run for its money!
    Specs:
    2954cc 7M-GTE Straight 6
    Toyota CT-26 Turbocharger
    HKS Turbo Elbow
    HKS T-16 Exhaust (elbow back)
    R154 5-speed Manual Gearbox
    TEIN HR Coilovers Front & Rear (Height Adjustable)
    Fensport Brake Discs (Front & Rear)
    PAGID Fast Road Brake Pads
    17" Matrix Shadow Alloys on 235/45/17 Michelin Pilot Premacy's
    Not running any engine mods as yet as it's currently being rebuilt (new rod and main bearings, thrust washers, gaskets, 20thou oversize pistons, water pump, oil pump, ARP head studs, new valve seat inserts & valves), but once done, i'm moving over to the N/A models rocker covers with the Lexus IS300 Coil-on-Plug System (removing the ugly ass coil pack), and shimming the wastegate to bump me up to 11psi of boost (if needed, the elimination of the stock cat and elbow means i'm already spooling quicker and building more boost).
    Interior is Grey Leather - although a recent theft from the interior means its now slashed to and will cost £1200 to repair, so i'm throwing a grey cloth interior in for the time being.
    Has all the goodies - Electric Windows, Electric Mirrors, Electric Seats, Fully Adjustable Climate Control, Cruise Control - all of which works perfectly!
    See? I'm retro all round!
    Main Rig
    Intel Core i7-2600K (SLB8W, E0 Stepping) @ 4.6Ghz (4.6x100), Corsair H80i AIO Cooler
    MSI Z77A GD-65 Gaming (MS-7551), v25 BIOS
    Kingston HyperX 16GB (2x8GB) PC3-19200 Kit (HX24C11BRK2/16-OC) @ 1.5v, 11-13-13-30 Timings (1:8 Ratio)
    8GB MSI Radeon R9 390X (1080 Mhz Core, 6000 Mhz Memory)
    NZXT H440 Case with NZXT Hue+ Installed
    24" Dell U2412HM (1920x1200, e-IPS panel)
    1 x 500GB Samsung 850 EVO (Boot & Install)
    1 x 2Tb Hitachi 7K2000 in External Enclosure (Scratch Disk)
    Entertainment Setup
    Samsung Series 6 37" 1080p TV
    Gigabyte GA-J1800N-D2H based media PC, Mini ITX Case, Blu-Ray Drive
    Netgear ReadyNAS104 w/4x2TB Toshiba DTACA200's for 5.8TB Volume size
    I refuse to participate in any debate with creationists because doing so would give them the "oxygen of respectability" that they want.
    Creationists don't mind being beaten in an argument. What matters to them is that I give them recognition by bothering to argue with them in public.
    Mar 2005
    houston TX USA
    lol, do they actually do a smog test? or just check the ecu readings? cuz with a quick tune/chip you can get the computer to not report anything about emissions.
    emptiness
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    I love old toyotas, and supras are the king! Nice ride!
    Formerly XIP, now just P.
    Oct 2007
    East Sussex
    Two speed idle test for that, even on vehicles from this year (although vehicles from 2001 also have to have an NOx test)
    Allowed 3.5% CO2 and 1200ppm particulate emissions
    If it fails at 800rpm, but passes at 1500rpm, it gets an overall pass.
    Last time it was tested, it got 0.12% CO2 and 580ppm particulate
    The ECU on this is not OBD compatible - proprietary TCCS system, no monitoring available besides Vf.
    Main Rig
    Entertainment Setup
    Nov 2005
    Chicago, IL
    I have a friend with a MKIV and a 1jz, very nice car.
    Congrats.
    Asrock Z68 Extreme4 Gen3
    •i5 2500k @ 4.5ghz - 1.32v - CM Hyper 212 Evo
    •G.Skill F3-12800CL9D-8GB
    •ASUS 7850 @ 1250//5800
    •Corsair TX650 V2
    •Dell 3007WFP
    •Win 7 64 Ult
    Oct 2007
    East Sussex
    Quote Originally Posted by EnJoY View Post
    Hehe - thanks for that - i do intend to clean up the engine bay, but the newly engine has to be shoehorned in first before i can do anything. I need to rewire a fair bit of the engine bay first though - too many brittle/frayed/worn cables. Had to get a new (yes, NEW) crank position sensor....that was fscking expensive too!
    Maybe a new O2 sensor as well....just for kicks
    Main Rig
    Entertainment Setup
    Oct 2007
    East Sussex
    MkIV's had the 2JZ-GE/2JZ-GTE (3.0, 2994cc)
    Japanese MkIII's had the option of the 1G-FE/1G-GE/1G-GTE (2.0), the 1JZ-GTE (2.5) and the 7M-GE/7M-GTE (3.0, 2954cc) - all of them straight 6's
    Main Rig
    Entertainment Setup
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Nice ride, always liked the supra's even though I wasn't a fan of straight 6's, they sort of made up for that IMO..Just a good car..Enjoy!
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Nov 2005
    Chicago, IL
    My bad, its a MKIII with a 1jz
    Quote Originally Posted by Kai Robinson View Post
    •Corsair TX650 V2
    •Dell 3007WFP
    •Win 7 64 Ult
    I am Xtreme
    Apr 2005
    Upstate, NY
    Hot ride dude, I love the 80's and early 90's Supra's
    Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
    MSI H55-GD65 Motherboard
    G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
    Sapphire Radeon 5750 1GB
    Samsung F4 320GB - WD Green 1TB
    Xigmatek Utgard Case - Corsair VX550
    Oct 2007
    East Sussex
    The reason i like the straight 6 engine is because its inherently balanced, meaning smooth power delivery, and not just in terms of NVH (Noise, Vibration, Harshness)
    The 7M, because of its long stroke, makes for an incredibly torquey engine - plenty of grunt on the bottom end.
    Granted, a straight 6 isnt necessarily the most practical, and a V6 would suffice, but a 7 bearing engine vs a 5 bearing engine....i'd rather go with the option thats likely to last the longest
    I need to re-do some of the paintwork - i was just going to get the rear arches sanded, re-primed and blended, the front bumper and rear spoiler stripped, primed and resprayed in their entirety - but for the moment, will have to suffice for the 280bhp monster thats going in the sizeable hole i can stand in :p
    Main Rig
    Entertainment Setup
    May 2005
    St.-Petersburg, Russia
    time for 402m ^^
    May 2005
    Ker-Pow !
    Jun 2002
    UK
    Nice car, but watch for the head gaskets as apparently they are very fragile and costly to repair.
    http://www.supras.org.nz/techinfo/bhg.htm
    Mar 2005
    houston TX USA
    dunno bout the mk3, but alot of cars, the head gasgets can be one of the easier parts to replace.
    emptiness
    Apr 2005
    Any car with an overhead cam is gonna be a nightmare to change out a head gasket. Even worse on turbo or supercharged cars.
    Core 2 Duo E8400 @ 4ghz
    2GB PC2-6400 @ 445/890 4, 4, 4, 12
    ATI HD4850 @ stock
    Gigabyte P35-DS3L
    El Cheapo 500w PSU with dual 12v rails
    16X DVD+/- R/W
    Mar 2005
    houston TX USA
    Quote Originally Posted by Rickster_64 View Post
    ohyeah lol, haha i was thinking valve covers.
    emptiness
  18. #18
    Jun 2007
    Northern California
    Quote Originally Posted by NickS View Post
    And then they redesigned them to look like crap.... same with the RX7... Z/ZX always looked good though....
    Nice Ride!
    |-------Conner-------|
    RIP JimmyMoonDog
    2,147,222 F@H Points - My F@H Statistics:
    http://fah-web.stanford.edu/cgi-bin/...e=Conman%5F530
  19. #19
    Aug 2006
    Its a nice car. You must be pretty daring with that thing given the price per litre of gasoline where you live. I don't care about driving a 6 litre car over here in the US, but you must feel the pinch at least a little.
  20. #20
    Oct 2007
    East Sussex
    Well £70 per fill of the tank every other day!
    Bear in mind though - the price is 90% tax :/
    The headgaskets on Mk3's are well known - i've had one before this one ('88 Normally Aspirated pre-facelift) and the HG on that went. The reason for it is because Toyota was going to use a different headgasket originally, and torque spec for that was 56lb/ft. They later changed the gasket type but not the torque spec. Set of ARP head studs and a regular gasket will see you able to push 12-psi of boost without much issue.
    Changing the head gasket on these is a pretty simple job. Remove the exhaust downpipe, unbolt the fuel lines and wiring, take the crossover pipe off, remove valve covers, take out headbolts - lift off the whole inlet/head/exhaust/turbo in one go. Remove old buggered gasket, scrape clean, put new gasket on, studs in the block, lower the head over it, install the studs and voila - all done.
    The HG usually blows between the water galleries on these, although in the event that you end up with oil/water mixing - you have to strip it down and rebuild with new bearings, oil pump and water pump.
    Might as well go for a new set of oversize pistons (mine are ceramic topped, 20 thou over) while its stripped down!
    Main Rig
    Entertainment Setup
  21. #21
    Oct 2007
    East Sussex
    First of all, i have to say this....
    "YEEEEHAH!!!"
    *ahem*.
    Sorry
    Basically, i just got a bunch of goodies off my mate ed. First of them being a 57 trim CT26 Turbo (hybrid, Garrett T4 CHRA, CT26 housing)....for FREE!
    Second, i got a set of 2JZ coils from a late model aristo VVTI that i can use to replace the butt ugly stock coil pack and finally fit a set of the far superior N/A cam covers.
    Third, he just offered me a respray for FREE (labour wise) if i get the materials needed. This is for a bare shell respray in Toyota 3E5 Red...
    I'm all buzzy and 'ding!' right now
    Main Rig
    Entertainment Setup
  22. #22
    Xtreme X.I.P.
    Aug 2002
    That's a very nice ladies car! That deep pink colour really suits it too.
    Regards
    Andy
  23. #23
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Very nice! I personally preferred the MkIV even though it was a tubby car, I just liked it's curves. That car will be a downright beast though, goodluck tuning/building her
  24. #24
    Oct 2007
    East Sussex
    ITS NOT PINK! ITS RED GODDAMMIT!
    Okay, so the pain has faded....a lot....it was sat in the sun for several years though
    The respray should sort it though
    Main Rig
    Entertainment Setup
  25. #25
    Xtreme Cruncher
    Mar 2005
    venezuela caracas
    kai a good detailer can bring life to that paint, i know it because im one
    before
    after
    Incoming new computer after 5 long years
    YOU want to FIGHT CANCER OR AIDS join us at WCG and help to have a better FUTURE
