Results 1 to 3 of 3
Thread: [Mini test] NorthQ Giant Reactor 1KW Psu
    Dec 2006
    Denmark, Horsens
    Nosfer@tu has sent me a NorthQ Giant Reactor 1000 WATT PSU, and I will do a review of it. I have the rig to do some real life load testing on it. So here we go.
    By giraffen, shot with Caplio R6 at 2007-11-06
    By Giraffen
    Specifications :
    +3.3v : 25A
    +5v : 30A
    +12v1 : 35A
    +12v2 : 35A
    -5v : -
    -12v : 0.3A
    +5Vsb : 3A
    +3.3V and +5V combined load must not exceed 200W
    Noise Level:
    12 - 17dB at load up to 400Watt
    17 - 25dB at load between 400 - 800Watt
    +25dB at 1000Watt load
    Cable configuration:
    1 x 24/20pin ATX cable
    1 x 8pin detachable motherboard extension cable (4pin+4pin)
    4 x 6pin PCi-express cable (Quad SLi capability)
    8 x S-ATA plug on 2 cables (4 on each cable)
    8 x Molex plug on 2 cables (4 on each cable)
    1 x Floppy plug on 1 cable (1 on molex rail)
    A total of 8 cables from Power Supply
    Key info :
    Extreme EPS12V 1000Watt PSU
    Active PFC
    24-pin ATX extension (backward compatible with 20pin)
    135mm fan installed
    Fan speed control function inside
    Full cable sleeving and black connectors
    8 * S-ATA lines
    4 * 75Watt PCI-Express line for Quad SLi
    Black coated case and black FAN grill
    Dimension:150*86*160mm(W*H*L)
    By Giraffen
    The load messured on the hole of the PSU is between 425-720W, during my benching.
    Measured 12 Volt, it is stable as a rock. Between 12,05-12,07 Volt Very impressive
    And 5V line here, Between 5,11-5,14Volt
    as you se I have a tangmeter (is that the english word ? ) but you need to seperate each different volt line, 3.3, 5.5 and 12 volt lines before you can use it. And that would be QUITE a task. So I dident find the use for it this time
    Conclusion:
    It is a very power full PSU. Cable length is long enough for a tower cabinet. And noise….. I didn’t hear it. The price is about 165€. I think it´s a Really good buy for people who have a power full system, but dont want to pay 200+ Euro
    For more specs http://www.northq.com/products/power...4775-1000.html
    OCTeamDenmark Crew - Cooled and sponsored by CoolerKit.dk
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    I like your first user review
    And XS users, If you have questions, suggestions or want my mate Giraffen to test somthing fell free to ask
    Thx giraffen
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Looks good champ and do you remember what i said about the cpu .
    Best Regards.
