Has anybody tested this config.
I'm wondering if it would be better then just striaght water or actually be worse.
I'm trying to avoid condensation.
OPP
OPP
Geese you guys are slow in this forum
I tested the 5V 80w pelt and it works good, about 7c.
OPP
Is that for you nb Opp ???? I really hadn't thought about running an 80w on 5v
24/7 Work & Play Rig
Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
trying to avoid condensation is like trying to not eat
Just soak it all in dielectrisc grease or wax it
What I would like to do is just use a straight waterblock. All I have is this pelt block MCW40T, 80w built in, so I'm trying to get it to work like staright waterOriginally posted by SpicyHuevos
OPP
but condensation kicks in at 10c right
No, condensation happens at any temp below ambient (depending on humidity levels).
9900k @ 5.1Ghz
Asus Maximus Hero XI
32GB (8 x 4) Gskill @4000
Strix 2080 Ti OC
OS & Apps: Samsung 970 Pro 512GB
Games: Samsung 970 Pro 1TB
Storage: Crucial M500 2TB
Seasonic Platinum 1000W
Phanteks Evolv X
Thanks Mickey,
I could accually just go by swiftech and pick one up, so keep that one .
I was hopeing to maintain the plate temp about ambient while the NB was running, this would be better then water. I'd have to drop the voltage a little more I think.
OPP
i have a question. i'm using mw50-T, the peltier power connecters are very hot. Why is it so? Is there anything wrong? And what's the solution. Thank you so much.
but i'm using an Antec 480 watts. According to the winbond hardware monitor, it say that my 12+ is at 11.86 volt. So what do u think? THanks.
