+ Reply to Thread
Results 1 to 6 of 6
Thread: load on HT cpu question
    Xtreme Enthusiast twiztdskatr's Avatar
    Dec 2002
    30N|95W
    0
    do you have to use two programs to load your cpu on say an 800fsb cpu with ht? or is one fine?
    Xtreme X.I.P.
    Nov 2002
    Shipai
    1
    most apps are single thread optimized, the programm is waits for one thread to finish before it starts a new thread.
    i think the most performence increasement can be seen when running multiple single thread optimized apps or of course multi thread optimized apps.
    so basically, yes.
    Jul 2002
    UK
    0
    i use 2 so that both alu's get maxed otherwise itll sorta use 50% of both and only vary slightly between them.
    i have no idea what saaya is going on about.
    Banned Amoeba Assassin's Avatar
    Apr 2003
    0
    for sandra,
    burn in on heavy puts cpu usage at 100%
    it also uses about 265 megs of ram
    my system chugs like a stoner running the mile
    Xtreme Member Bleam!'s Avatar
    Apr 2003
    french for for rent
    0
    for HT cpu's you should use Toast.exe two times, it uses both threads ...
    3200+ Venice @ Stock | MSI K8T Neo2 | 2×512 pc3200 TwinMoS @ Stock | Hercules 9800Pro@XT |
    4400+ X2 @ Stock | DFI NF4 SLI-D | 2x512 OCZ 4000+ VX Gold | 2x 7800GTX @ SLI | 2x 320GB Western Digital SATA | 74GB Raptor Western Digital | OCZ 520W Powerstream | Fully watercooled |
    "why get a 500dollar videocard to benchmark with grafics of the sixties"
    CCW
    Guest
    Is this for burn-in?
    Folding can make use of hyperthreading.
    Craig
+ Reply to Thread
