+ Reply to Thread
Results 1 to 13 of 13
Thread: Finaly got my xp but....
    Xtreme Member morphling1's Avatar
    Jun 2002
    Slovenia
    0
    Ok, today I got me a xp1700+ agoia y week10.
    But I just can't run it stable more than 1.9GHz, no matter the voltage I use.
    But I'm pretty sure that the psu is holding me back check out the voltages I'm running at
    Psu is some 350W maxpower cheap thing.
    Can I expect better oc. with better psu?
    Xtreme Mentor
    Jun 2002
    PA, USA
    0
    Very well could be your problem.....but that's still a nice clock
    | 1.6GHz Intel E2140 @ 3.2GHz 24/7 | Abit IP35-E | 4GB Corsair XMS2 PC2-6400 | 512MB XFX Radeon HD4770 | 100% CPU OC & 24hr Prime95 stable | Heatware |
    Jun 2002
    Rio de Janeiro, Brazil
    0
    hehe
    for sure this should hold you..
    btw.. look my old psu;
    and thats idle ;p
    muaaahaha
    Jun 2002
    Slovenia
    0
    UaZa, thats even worse than mine considering lower cpu power need, but no for the big q. did you improve stability with new psu?
    For my new psu, I'm thinking of Antec 400W
    Xtreme Member Malecky's Avatar
    Jun 2002
    Slovenia
    0
    I was looking at the Antec specs and I tell you the Truepower 330W is overkill your lines will be just as good you know why. And you dont use pelts so no need for 12V line power.
    Save your CASH I guaratee the 330W will be more than enough. Still havent made the test... Primoz is screwing me all the way... and they are gettin lazy:P
    Jun 2002
    Slovenia
    0
    I wasn't thinking of true power, but smartpower, and also, I think this could be the end of me looking for psu, so I wanna by good one.
    Jun 2002
    Slovenia
    0
    Ahm.... OK, but think Slovenian not American... these guys here go a little overkill just becouse their HW is half the price than here in Slovenia.
    Well the Smartpower will do too, but in my opinion not nearly as good as the Truepower.
    May I remind you I will still get a sample from redrat and I told matej I will buy it, but not now becouse the Leadman does the job more than well.
    Jun 2002
    Slovenia
    0
    Ok, one question, could bad psu be responable for blue screens, if I oc. a little to much. Does anybody have solid proof that 5+ voltage of 4.6-4.7 causes instabilities. Cos' if that's so, I'm gonna have to buy new one,
    Hey Malecky, do you have any better psu, that you can lend me for test to see if it's any better. I don't wanna buy new if it won't get me better oc.
    Jun 2002
    Slovenia
    0
    Morph you REALY need a new PSU and I guaratee its the couse off all your problems. Lending you one wuld be pathetic....becouse I dont have any to lend... had to w8 a long time before I got happy with the purchase of the Leadman.
    Jun 2002
    Slovenia
    0
    Ok, cool no problem
    Xtreme Member King_of_qb's Avatar
    Jul 2002
    0
    get a enermax 400w they are psu
    DFI Lan Party Ultra B
    Athlon Xp 2500 unlocked
    BBATI Radeon 9800 xt 450/400
    2x OCZ PC3500 Platinum Limited Edition Bh-5
    SLK900-U & 120mm 200CFM fan
    80GB 8MB WD JB800
    Lite-On Dual Format 4x DVDRW
    Lite-On 48x24x48 CDRW drive
    Kingwin KT-436 Blue with 3 blue tinted windows
    TTGI 420w psu
    KDS 19" Flatscreen Avitron
    Logitech Mouse & Keyboard
    FujiFilm 3.2mp 6x opt zoom
    Klipsch 4.1 speaker system
    www.OverclockersHQ.com
    3dmark score
    Jun 2002
    Slovenia
    0
    Duh, there are thousands of threads and post out there that contradict your opinion, and I think they are right. enermax 5V voltage is crap even on the 550W model so no go, for sure the Truepower Antecs are the best right now with the exception of PCpower&cooling becouse of their price tag.
    Jun 2002
    0
    Actually, the 550watt model was the only one that had decent 5v lines under load. With the adjustable Pots, the Enermax 550 was fine.
    That said, i still prefer my Antec 550watt True Power
    Set me free.
    A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
+ Reply to Thread
