+ Reply to Thread
Results 1 to 7 of 7
Thread: How many more will base on Chip LGA775
    Aug 2006
    0
    Hi
    Does anyone know how many more of generation's CPU will base on LGA775 ? the latest on is 45nm...so how many more will come out??? Please educate me.Thank you.
    P5W DH Deluxe, E8400 3.0Ghz 2 water cooling: Nautilus for NB,SB & Chipset and Storm for CPU w/ P120.3 Rad, swiftech pump.
    http://valid.x86-secret.com/show_oc.php?id=179464
    Xtreme Cruncher ChaosMinionX's Avatar
    Oct 2006
    Boston, Massachusetts
    1
    Penryn will probably be the last, as Nehalem which is due Q4 2008 (est.) will be Socket H (715 pin) LGA1366.
    Aug 2006
    0
    Thank you for the info.
    BTW: if that the case I wonder the Geforce 8800 still good till the end of 2008?????
    Oct 2006
    1
    Quote Originally Posted by ntvh View Post
    Thank you for the info. I just wonder if that the case we will have to c/o the phase cooling also unit ????
    Come again? Little hard to understand the last bit after c/o
    Aug 2006
    0
    My mistake. sorry. Will the new LGA1366 will work with GeForce 8800 card?
    Oct 2006
    1
    Yeah PCIE isnt changing, only Socket is changing because of new Onboard memory controller, and interconnect feature.
    Aug 2006
    0
    Thank you.
    One more thing, I guess all the water block or Phase change cooling for CPU will have to replace for the LGA1366 ???
+ Reply to Thread
