+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: Leopard Hacked
    Xtreme News Addict Pinnacle's Avatar
    May 2005
    Winnipeg, Manitoba, Canada
    0
    Leopard Hacked
    Install Leopard on your PC in 3 steps!
    Step 1. Getting things ready
    Burn the DVD Image onto a Single Layer DVD-R using a software like Nero.
    Format the USB Flash Drive and the drive label should be "Patcher" without the quotes. Please note it has to be "Patcher" only and nothing else for the patch to work when we apply it later.
    Extract the Zip file and put its contents into the USB Flash Drive.
    Now your USB Drive should contain a folder called "files", if it doesn’t then check to see where you have gone wrong.
    Step 2. Installing Leopard
    Now that you have the Patched DVD with you, you can now install Leopard. Pop in the DVD into the drive and boot into it by pressing F12 at the BIOS Prompt.
    Boot into the DVD and the installer should now load. It take a while though, so be patient.
    Select your Language and make sure you select Customize and you need to deselect all the packages that are displayed.
    Leopard will now install. This can take a while, so go grab yourself a coffee.
    It will ask you to Reboot, so go ahead and Reboot. Before rebooting make sure that USB Flash Drive is connected to the PC.
    Step 3. Patching Leopard
    Now that you have got Leopard installed, you need to patch it. Before we do that Boot into the Leopard DVD like the way you did before.
    Wait for the Darwin Bootloader to load. Once it loads up press F8. You should now see a prompt. Type -s and hit enter. The DVD will now load in Verbose mode. Watch for any errors. It should load without a problem because you have already installed Leopard.
    Once the setup is loaded select your Language. Once done you should now be seeing the Welcome Screen. Once there navigate to Utilities-Terminal.
    Once the terminal loads up, you now need to browse to your USB Drive, so follow the steps below, typing it exactly as it appears below in the Terminal.
    In the command line type the following as they appear here
    cd ..
    cd ..
    cd Volumes
    cd Patcher
    cd files
    Notice the space between cd and the 2 dots.
    Now its the time to run the patcher to make sure Leopard will work on your PC. Type the following into the Terminal.
    ./9a581PostPatch.sh
    The Patch should now run. You can answer Yes while removing the ACPUPowerManagement.kext
    After the Script is done, you should now be able to Boot into Leopard after you restart.
    Step 4. Congratulations! You’ve done the Impossible!
    Well that was it. Please note this has not been extensively tested, so most of your Hardware like Sound, Network may not work. If something goes wrong for you or you want to help us, then please join the discussion over at OSX86Scene. If you noticed I haven’t posted the links to the Torrent that contains the DVD image and the zip. Well I haven’t posted them because I am sure the lawyers over at Apple are going to sue the hell out of me. If you wondering where you can find them, then head over to Demonoid and search for it.
    Well here are few screenshots by Mac.nub over at the forums who could get Leopard working on his system.
    http://dailyapps.net/2007/10/hack-at...-3-easy-steps/
    "There's no chance that the iPhone is going to get any significant market share. No chance." -- Microsoft CEO Steve Ballmer
    Live Long And Overclock perkam's Avatar
    Sep 2004
    0
    Perkam
    May 2005
    0
    perky likes
    May 2005
    0
    click the link
    Banned
    Jun 2006
    Durham, NC
    0
    Quote Originally Posted by DerekFSE View Post
    I assume its a MAC OS from the 2 screens...
    Well done.
    Xtreme Addict RaZz!'s Avatar
    Aug 2005
    Germany
    8
    sometimes it could help not only to look at the pictures...
    the first sentence starts with:
    Well its been only a day since the Mac OSX Leopard was released officially by Apple [...]
    it's pretty obvious, isn't it?
    1. Asus P5Q-E / Intel Core 2 Quad Q9550 @~3612 MHz (8,5x425) / 2x2GB OCZ Platinum XTC (PC2-8000U, CL5) / EVGA GeForce GTX 570 / Crucial M4 128GB, WD Caviar Blue 640GB, WD Caviar SE16 320GB, WD Caviar SE 160GB / be quiet! Dark Power Pro P7 550W / Thermaltake Tsunami VA3000BWA / LG L227WT / Teufel Concept E Magnum 5.1 // SysProfile
    2. Asus A8N-SLI / AMD Athlon 64 4000+ @~2640 MHz (12x220) / 1024 MB Corsair CMX TwinX 3200C2, 2.5-3-3-6 1T / Club3D GeForce 7800GT @463/1120 MHz / Crucial M4 64GB, Hitachi Deskstar 40GB / be quiet! Blackline P5 470W
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    20
    dsont adding in a supper gui defeat the purpose of obsd
    3770k, M5E, kingston 2x4GB cfr
    samsung 2TB F4EG, samsung 840 250GB , CM690II, corsair 750tx
    I am Xtreme safan80's Avatar
    Oct 2004
    U.S.A.
    2
    Quote Originally Posted by Pinnacle View Post
    cd ..
    cd ..
    cd Volumes
    cd Patcher
    cd files
    that's standard unix. cd.. is ms' doing.
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    areca 16xx series controller with 4GB ecc of cache bbu running
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    May 2007
    0
    Quote Originally Posted by safan80 View Post
    lol yer most people fail to know its now unix based, basicly copying linux its the reason "no more viruses" of course there are some tho, but yer its unix based now.
    Gaming Rig
    Intel E6300
    Intel Mobo
    2 Gig OCZ 800 (800 5,5,5,15)
    Saphire Ati 4870
    22inch LG Flatron W2230S
    May 2006
    0
    Something tells me Leopard would have a hell of a time recognizing my 8800GTS and X-Fi. It must be nice to make an OS that only has to work on the hardware you handpick
    Xtreme Addict BrowncoatGR's Avatar
    Jun 2007
    Thessaloniki, Greece
    9
    Quote Originally Posted by cozwin View Post
    mac os has very little in common with linux. It is derived from FreeBSD but has undergone a lot of modification.
    Seems we made our greatest error when we named it at the start
    for though we called it "Human Nature" - it was cancer of the heart
    CPU: AMD X3 720BE@ 3,4Ghz
    Cooler: Xigmatek S1283(Terrible mounting system for AM2/3)
    Motherboard: Gigabyte 790FXT-UD5P(F4) RAM: 2x 2GB OCZ DDR3 1600Mhz Gold 8-8-8-24
    GPU:HD5850 1GB
    PSU: Seasonic M12D 750W Case: Coolermaster HAF932(aka Dusty )
    Xtreme Cruncher xVeinx's Avatar
    Jul 2006
    3
    I'll give you a hint.... Apple and Sun Microsystems...
    Xtreme Member dicecca112's Avatar
    Mar 2005
    0
    haha they exceeded there bandwidth. Wouldn't mind trying this
    Mac Pro 2X2.4GHZ Quad
    40GB OWC SSD
    6GB DDR3
    6TB Storage
    The Doctor Warboy's Avatar
    Oct 2006
    Michigan, USA
    0
    What is Leopard?
    You have been sig quoted my friend....
    My Rig can do EpicFLOPs, Can yours?
    Once this baby hits 88 GigaFLOPs, You're going to see some serious $@#%....
    MIA - XT4, will be missed. ST1 Active.
    Current OS Systems: Windows XP 64bit Build 3959, Windows 7 64bit SP1 Ultimate, Ubuntu 11.10 64Bit
    Banned SOLDNER-MOFO64's Avatar
    Nov 2006
    BEYOND THE SUN - SCOTLAND
    0
    Nice, I think I'll have a mess with Leopard tonight....just for the hell of it.
    What is Leopard?
    Quote Originally Posted by Warboy View Post
    ffs, now we're quoting simple questions.
    I give up
    Xtreme Cruncher Origin_Unknown's Avatar
    Jan 2005
    England
    22
    lol i might give this a try
    My Free-DC Stats
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    Xtreme Enthusiast The_Beast's Avatar
    Jul 2007
    Wisconsin
    0
    Why would I want an inferior product installed in my computer???
    - Gigabyte DS3L P35 - C2Q Q6600 - Antec NSS NSK4480B - Corsair XMS2 2Gb - Kingston Hyperx 4Gb - Sapphire 2600 XT - 2 Samsung F3 2TB - 2 WD Black 750 GB - 2 WD Black 1TB - Seagate 320 GB - Dell UltraSharp U2410 - Logitech Z4 - Corsair 750HX - Windows 7 Pro and XP Pro Dual Boot -
  18. #18
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    Quote Originally Posted by The_Beast View Post
    Heh I was wondering the same, who really wants to do this
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
  19. #19
    Xtreme Addict cky2k6's Avatar
    Jan 2006
    0
    I won't do this for the same reasons I don't use linux that often on my pc, lack of hardware support. I don't need an os that has no support for sound/ethernet/video/wireless...
    Core i7 920 3849B028 4.2ghz cooled by ek hf | 6gb stt ddr3 2100 | MSI HD6950 cf cooled by ek fc | Evga x58 e760 Classified | 120gb G.Skill Phoenix Pro | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
  20. #20
    Xtreme Member `danny's Avatar
    Mar 2007
    0
    Cool but I'll pass on this
    Intel Core i7 2600K~stock for now
    ASUS P8Z68 Deluxe
    2x4GB Patriot Viper@DDR3 1600
    MSI Twin Frozr II GTX 570~stock for now
    OCZ GameXStream 700W PSU
    Thermalright Ultra 120 Extreme
    Logitech G15 & MX518
    Thermaltake Armor Series
    SPDIF out (optical) --> Headroom 2005 DAC --> Little Dot II++ --> Senn HD595s
  21. #21
    Jan 2007
    Stephens City,VA
    0
    i will try this eventually, i tried tiger before and i lilked it
    i have ran tiger on at least 3 systems and it worked with everythig
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
  22. #22
    Jul 2007
    Wisconsin
    0
    Quote Originally Posted by SparkyJJO View Post
    just so people have "option" that they don't need/use
  23. #23
    Xtreme Enthusiast Machinus's Avatar
    Jun 2007
    0
    Congrats to this hacker! Although, I wonder who cares about mac os??
  24. #24
    Oct 2004
    U.S.A.
    2
    I do. just so I can check it out.
  25. #25
    May 2007
    0
    This has been around for quite some time.
    I tried the "Mac OS X86" project at 10.4.3, and 10.4.9.
    All of the hackers are doing a great job getting Mac OS X to work on AMD and Intel processors.
    The only thing holding me back from this is the no support for nVIDIA 8000 series.
    There are no drivers for the 8000 series.
    When you move a window, the content would be fall behind.
    Everything was sketchy.
    It took about 15 minutes for me to get my ethernet controller, audio, and CD-ROM drive up and running 100% under Mac OS X, but I couldn't enjoy the eye candy of Mac OS X, and I was just doing it to experiment.
    Gigabyte P35-DQ6 | Intel Core 2 Quad Q6700 | 2x1GB Crucial Ballistix DDR2-1066 5-5-5-15 | MSI nVIDIA GeForce 7300LE
+ Reply to Thread
