Results 1 to 25 of 25
Thread: pci-e 1.0 vs 2.0
    Oct 2006
    Auckland, New Zealand
    pci-e 1.0 vs 2.0
    Is there any notable difference?
    i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
    Jun 2006
    Seattle
    And how will these two perform in Tri-crossfire or Quad-crossfire?
    Strange how little info is out on this stuff.
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    2.0 is capable of twice the bandwidth thus the ability to run tri and quad crossfire. 1.0 will not support them.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    Oct 2006
    If using only a single pcie 2.0 card in a 1.0 slot, will there be virtually no performance hit?
    Core 2 Duo E6300 @ 3.2Ghz (460 FSB/1.4v)
    Gigabyte GA-P35-DS3R (Rev. 2.0)
    2x1GB Crucial PC2-8500 @ 920Mhz (4-4-4-12/2.2v)
    eVGA 8800GTX @ 630/1000
    SB Audigy 2 ZS
    Samsung SATA2 320GB HDD x2 in RAID0
    Antec NeoHE 550W PSU
    Windows Vista Ultimate (32-bit)
    Tuniq Tower 120
    And some other stuff in a CM Stacker T01
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Quote Originally Posted by jimmyz View Post
    Triple SLI & CrossFire will run on PCI Express 1.0 as well.
    PCI-Express 2.0 is more bandwidth, plus more slot power in short.
    Coding 24/7... Limited forums/PMs time.
    -Justice isn't blind, Justice is ashamed.
    Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P. ), Juan J. Guerrero
    Jun 2006
    Quote Originally Posted by BenchZowner View Post
    links? results?
    DFI LP LT X-38 T2R
    Thermaltake 1KW Psu
    Sep 2006
    Inside a pot
    Initially Nvidia plans to enable triple SLI support for the top-of-the-range GeForce 8800 GTX and Ultra graphics cards, however, eventually it may support 3-way configurations of other GPUs as well. Systems with three graphics cores will be powered by Nvidia nForce 680i as well as nForce 780i platforms with the former supporting PCI Express 1.1/1.0a, whereas the latter featuring PCI Express 2.0 along with a special “BR04” switch for more efficient multi-GPU operation.
    Jun 2006
    COLORADOOOOO
    call me crazy but i still think we need to work on single cards more then making dual/trip/quad card solutions work...
    Jun 2007
    someone did a test of a 8800gt in 16x and in 8x and there was <1&#37; difference between the 2. The differnce between 16x and 16x v2 should be even slimmer.
    CPU:X3210 G0@3.6 (8x450 1.48v)
    MOBO: Asus P5K Premium, bios 402
    RAM: 4x 1GB DDR2-1066 @ 1080 5-5-5-15 2.3v
    CASE: antec 900
    GPU: XFX GeForce 7900gt @600/1900
    PSU: silverstone OP1000
    Cooling: MCP655, Apogee GT, MCR320-QP-K
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    but u have 200W through the slot V less than 100 in the normal pci-e16x
    5930k, R5E, samsung 8GBx4 d-die, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB , CM690II, swiftech h220, corsair 750hxi
    Jun 2007
    power wise 2.0 makes it possable to get rid of the 2nd power plug on the Graphics Card
    CASE: antec 900
    Oct 2006
    ok, so Im not making a compromise if I buy a PCI-E 2.0 card and put it in my P-965 chipset with PCI-E 1.0
    Sep 2006
    Inside a pot
    correct @ above post
    Oct 2007
    So if I put a pci-e 2.0 card in my 1.0, is it going to work how it's supposed to or is it going to have less bandwidth?
    Banned
    Jun 2006
    Durham, NC
    Quote Originally Posted by ser710 View Post
    It'll be backward compatible with PCI-E 1.0, the 2.0 card will just be limited to the bandwidth the v1.0 slot is capable of providing, as I understand it--kind of like plugging in SATA3G drives to SATA1.5 headers, although no hard drive saturates the original 1.5Gbp/s pipe as of yet.
    Plus, PCI-E 2.0 slots can deliver 150w of power through the slot itself as opposed to 75w on PCI-E 1.0 slots.
    Jul 2007
    SF bay area, CA
    is there a bench with pci-e2 compliant cards in pci-e1 v 2
    Banned
    Jun 2006
    Durham, NC
    I highly doubt there are any cards out there saturating the bandwidth of a PCI-E x16 v1.0 slot at the moment.
  18. #18
    Xtreme Cruncher
    Jul 2007
    Santa Clara, C.A
    Is the 8800gt the first ever PCI-E 2.0 consumer video card?
  19. #19
    Jul 2007
    SF bay area, CA
    no its the first official pci-e2 card the 2900xt dose pci-e2 also just as an amd approved oc
  20. #20
    Apr 2007
    I had the same exact question. Is a 8800gt card going to work in an ABIT IP35 Pro LGA 775 Intel P35 ATX motherboard?
  21. #21
    Apr 2007
    I just read in an internet review of the 8800gt that it's compatable with a PCI-E slot.
  22. #22
    Jul 2007
    SF bay area, CA
    teh diffrence on pci-e1-2 is that 1 has 100mhz and 16bit addressing space and 75W pci-e2 has 200mhz 32bit addressing space and 200W and most cards with external power will be pci-e1 compatable
  23. #23
    Aug 2007
    Finland
    Hmm someone here found this and I grabbed this..sorry, I can´t remember your username but thanks anyway.
    The big question, if this is correct http://www.bit-tech.net/news/2007/06...ports_pcie_2/1 makes me wonder, if P35 is pci-e 2.0 compatible, are all the P35-based motherboards pci-e 2.0 ready? I mean, is it possible to enable pci-e 2.0 via biosupdate or something like that? I´d say that would be cool, even if the advantage isn´t so big.
    ps. waiting for my Q6600 G0
    2500k / HD6950 / 8gb vengeance / 60gb agility 3 / asrock z68 pro3
  24. #24
    Jan 2006
    its from june, so if theres no news about it still, its safe to say p35 is pci-e 1.1 (not 1.0, I don't think that even reached production mobos...) only. and pci-e 2.0 supports 150w, not 200w. finally, for any posters in the future that AGAIN feel the need to ask, yes, cards designed for either slot are compatible with both standards.
    Core i7 920 3849B028 4.2ghz cooled by ek hf | 6gb stt ddr3 2100 | MSI HD6950 cf cooled by ek fc | Evga x58 e760 Classified | 120gb G.Skill Phoenix Pro | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
  25. #25
    Sep 2006
    California
    you will not lose any performance whatsoever by running a PCI-E 2.0 card in a PCI-E 1.1 slot.
    My Videos
    GRID Demolition Derby * GRID Camaro vs. Mustang * Audiosurf - Speed Racer
    I Shot the Hosties * Slightly Stupid * Dump Truck
    Intel Haswell 4770K * 2x8GB Mushkin Redline DDR3 1866 CL9 * Asus Maximus VI Gene * Sapphire 7870 GHz Edition
    500GB Samsung 840 Series SSD + 2TB WD Raid Edition 3 magnetic * SilverStone Temjin case * Corsair TX750 PSU * Corsair H60 water cooler * Win7 Pro x64
