+ Reply to Thread
Results 1 to 16 of 16
Thread: I need recommendations for some sort of ram cooling solution
    Sep 2004
    0
    Alright, after having one Ballistix D9 die on me and the other steadily failing (Something has to be wrong with it. Running at 400mhz and 1.8v with it nearly burning to the touch? Either my board is overvolting which is doubtful or something within the ram is shorting out, no idea honestly) I want to make sure the sticks I get from RMA will NOT burn out on me this time.
    I want some high air flow movin sumbeetches. Open to suggestions, folks. Jury rigging, commercial solutions, whatever. I want these suckers kept cool.
    naokaji
    Guest
    corsair sells a ram cooler... 3 small fans in it.. provides some airflow and easy to mount... (ocz has one too)
    other than that its pretty much diy if you want to put a fan there... or, you could look for a cpu cooler that "spans" over the ram too to provide some airlfow.
    Xtreme Cruncher Origin_Unknown's Avatar
    Jan 2005
    England
    22
    I run my Crucial @ 2.2v so i've just put an 80mm fan ontop of them
    My Free-DC Stats
    You use IRC and Crunch in Xs WCG team? Join #xs.wcg @ Quakenet
    Xtreme Member DoomSayer's Avatar
    Oct 2006
    BELGIUM
    0
    i use a OCZ XTC cooler.
    it looks better then that corsair thing and probably has the same or better performance
    .:: Core i7 920D0 4Ghz :: Gigabyte GA-EX58-UD5 :: OCZ Platinum 3x2GB DDRIII :: Thermalright Ultra-120 eXtreme+Zalman ZM-F3 BL Push/Pull ::.
    .:: Powercolor HD5870 :: LG L226WTQ-SF 22" :: Corsair HX850W :: WD Velociraptor 300GB / Areca Arc-1210 4TB [RAID5] ::.
    iadstudio
    Guest
    there are quite a few decent RAM coolers out there. Just watch for Mobo compatibility. Some VGA slots will be close enought to the RAM to cause issues with some coolers. You really don't need much though. The RAM slots are a notorious deadspot for airflow. Just getting a little air flowing between the sticks will work wonders.
    Xtreme Mentor
    Jul 2004
    Ontario
    0
    I highly recommend the Antec Spot Cool. I have that cooling my Crucial ram.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
    Xtreme Member Walternowi's Avatar
    Mar 2006
    Arcadia, CA
    0
    Quote Originally Posted by cantankerous View Post
    +1 on Antec Spot Cool. I have 2 in my case, 1 directed at the RAM and the other at the PWM.
    AMD Phenom II X4 965 (C3)
    MSI 790FX-GD70
    2 x 4 Gb G.Skill Sniper PC3-14900
    PNY GTX 670 2 Gb
    Silverstone DA650
    Lian Li PC-A70B
    D-Tek Fuzion Rev.2/DDC-2 & DDCT-01 Top/Swiftech MCR220
    iadstudio
    Guest
    I use the OCZ XTC cooler. I can't compain. works well and quiet if it's on a controller. The spot cool migh work better, though.
    Sep 2004
    0
    ..A articulated neck mount anywhere fan.. In a PC!? Blasphemy!
    Why the hell don't these get more publicity? I plan on getting two myself, not for ram but for other things. Good suggestion there Cantankerous and Walt.
    The XTC is what I may buy.
    Xtreme Mentor
    Jul 2004
    Ontario
    0
    The Spot Cool really are terrific. I was dead set on getting either the Corsair or OCZ ram cooler, but with the ram retention brackets getting to close to the back of newer video cards, on newer boards, that option just isn't feasible anymore. The Spot Cool pushes more air at lower noise than either the Corsair or the OCZ ram cooler. The fact that it can be used for anything in your case is also a bonus. Have a hot NB/SB or PWM? Put one of these over it and watch your temps drop a good 10c. The fact they are 3 speed tunable means you are not set with either too much noise or not enough airflow.
    Asus P8P67
    Gigabyte GTX 460 1G
    Xtreme Addict strange|ife's Avatar
    Dec 2006
    Vegas ,NV
    0
    i use the ocz cooler, it works very well, is sturdy aswell.
    the spot coolers are also very good, ive had mine for a year and it still blows true. When i first saw it..my thought was "rice" but the sucker works, one of the best case accessory ive bought.
    Xtreme Member dr4gon's Avatar
    Sep 2007
    0
    ocz xtc cooler works amazing well and looks great!
    lol I was thinking of getting the spot coole for my NB heatpipe but after reading the reviews complaining of it's ugliness (but still very effective dont get me wrong) and I also thought of "rice" ... lol
    System
    Intel Core 2 Quad Q6600 G0 Lapped @ 3.4 Ghz
    4GB G.Skill Pi Black DDR2-800
    Asus P5K-Deluxe with WiFi
    ATi Sapphire 4870
    Creative X-Fi XtremeMusic
    Corsair HX620 620W
    Lapped Thermalright Ultra-120 Extreme
    Sep 2004
    0
    I would consider the OCZ cooler more rice to be honest. Especially with those blasted lights and grille design.
    Do they have a compatibility guide for the OCZ cooler? I don't want it to hit my card and all. Mobo is a DS3R incase they don't have a guide and someone has their own experience.
    Nerdy Powerlifter [XC] Synthetickiller's Avatar
    Jul 2007
    Down in the Bayou
    16
    Quote Originally Posted by Walternowi View Post
    I have the Antec Spot Cool and am VERY pleased with it as well.
    I also have an 80 mm fan sitting on my video card's heatsink that is also partially blowing on the ram (you have to see what I mean to understand what I am saying).
    The Antec is really nice. I picked one up at Best Buy.
    Xtreme Member PC_User's Avatar
    Sep 2007
    0
    I just put a 120mm Yate Loon that blows directly onto the ram from the 5.25" drive bays. Keep them cool, even under load.
    CPU: i7 920 C0 @ 3.8 GHz HT, 1.25v
    Cooling: Thermalright Ultra-120 Extreme
    Motherboard: Gigabyte EX58-UD5 w/ F9m BIOS
    Memory: 6GB G.Skill DDR3 1600
    Video: HIS 6950 2GB
    Hard Drives: WD Black 640GB, 2x WD Green 1TB
    Power Supply: Corsair 850TX
    Case: Antec P180B
    Monitor: 30" Dell U3011 H-IPS
    Peripherals: Logitech Illuminated + G7 | Sidewinder X4
    Sound: Auzentech X-Fi Forte | Audio-Technica AD700 | Logitech Z-2300
    OS: Windows 7 Professional x64
    Xtreme Member aiya's Avatar
    Apr 2006
    San Gabriel, CA
    0
    i have a antec spot cool directed my ballistix's. its on low since i like things quiet. good investment.
    AMD 550BE X2 @ X4 3.6GHz - Stock Heatpipe Cooler | Gigabyte GA-870A-UD3 | G.Skill DDR3-1600 2x2GB | eVGA GTX 460 SE @ 850/1700/2000 | X-Fi Platinum | WD 750GB Black | Lian Li PC-7B Plus - Corsair HX620 | 2xDell 2407WFP A04/A03 | Win 7 Pro x64
    http://www.heatware.com/eval.php?id=48222
+ Reply to Thread
