My 900 needs them bad. What kind should I get?
Hello Dusty lol, these are well overated, I think you should make your own, an old voile shirt or some fine gauze will cost you a lot less than the merciless prices they seem to charge! rant over
I got some of those nice aluminium mesh grills and they work a treat. Of course I sprayed them black first. Just watch the scratches unless you can afford a more professional job like powder coating.
I finally gave up with dust filters on the systems i've built. I just take my case out to my garage once a month and blast it out with my Craftsman air compressor. Nothing like 90psi of air to remove every fleck of dust on the whole setup in seconds.
"If the representatives of the people betray their constituents, there is then no resource left but in the exertion of that original right of self-defense which is paramount to all positive forms of government"
-- Alexander Hamilton
DFI LT X38 qx6850 @ 3.6g TJ-07BW
PA120.3/mcp655/GTX/mcw30+Tline+GSkill 4g
AHFDx2, 1T Samsung F1x2, Evga 8800gtx, W0132RU
Dell e1705 t7400 2g 200gHD 7900gs
http://www.heatware.com/eval.php?id=45541
hi Machinus, i use a piece of panty hose streched on an common fan grill, so it won't get sucked into the fanblades..
works flawless for me and is easy to clean with a vacuum cleaner
you dont want your room turning into a dust wind tunnel!
curent system
-Antec P182 case
-asus mobo
-AMD athlon 64x2 dual core 4000+2.10GHZ
-4Gs DDR2 OCZ PC2-8800 Gold Memory
-OCZ Vindicator CPU cooler
-ATI sapphire Radeon 2900 HD pro
-400 GB SATA seagate hard drive
-LG super multi cd/dvd drive
-OCZ gamextreme 700W PSU
BF2142-BF2-GEARSOFWAR-UT4
PlayerName-Lumb3rj4ck
You could grab those swiffer wipes too lol
Isn't it easyer to bring your case downstairs? Or outside , beacause of dust ?
they restrict airflow too much; dont bother. try to keep a clean room (id get one of those HEPA air filters if your place is really dusty ) and clean it maybe once a month?
the aluminum mesh filters work great.instead of having to clean my case out every 3-4 weeks i rarely need to do it more than once every couple of months.
Evga x99 classified
i7 6850k
2x16gb Gskill cas 14
2x Nvidia 980ti
Samsung 500GB 960 EVO NVMe M.2
EVGA SuperNOVA 1300 G2
Thermaltake X71 Tempered Glass Edition
EK D5 w/EK X top
XSPC D5 Photon 170mm Res/Pump and
Blue Barrow D5 Cover
EK Supremacy EVO Blue
EK-FC980 GTX ti x2
HW Labs GTR 240
XSPC RX360
HWLabs SR2 420
