+ Reply to Thread
Results 1 to 2 of 2
Thread: Temp Confusion
    Xtreme Member BTK's Avatar
    Sep 2006
    0
    Temp Confusion
    GIGABYE GA-P35-DS3R
    Intel Core 2 Duo E6750 w/ Scythe Infinity HSF
    2x1GB DDR2-800 Crucial Ballastix (Micron D9GMH)
    eVGA 8800GTS 320MB Superclocked (163.69 WHQL)
    WD 250GB 7200RPM SATA
    CorsairHX 520W PSU
    Vista Home Premium 32 Bit
    Testing my overclock in orthos.
    It's been going 13 minutes now and should be enough for max load temp.
    Vcore @ 1.36 in BIOS and stock is 1.35 - CPUZ knows nothing about vcore.....
    RAM @ 1.8V - I know it's micronD9 but I like 1.8V better than 2.2V even if it's rated for 2.2V.
    Now what do I use for temps? All the programs are way different readings.
    GIGABYTE-GA-P35-DS3R
    Core 2 Duo E6750
    Tuniq Tower 120
    # GB RAM Crucial/GSKILL
    XFX GTS 250
    WD Cavair 250GB 7200RPM SATA
    CM 690
    CorsairHX 520W
    Vista Home Premium X64
    Samsung 220WM 22"
    Xtreme Member Severance's Avatar
    Nov 2006
    Ontario Canada
    0
    Coretemp
+ Reply to Thread
