+ Reply to Thread
Results 1 to 6 of 6
Thread: How to get hold of LN2/DI
    Mr. Boardburner Martijn's Avatar
    Jun 2005
    the Netherlands
    3
    First of all: I'm not going to use this in my computer, so you can continue browsing somewhere else now
    But I might just nick some leftover stuff to my home
    For the other people:
    I am, together with a friend, making a rocket-propelled radio controlled car for school. We've done a lot of research on it and one of the problems we came across was cooling the monster. Well of course I thought of LN2 or DI . What do you think is the best way to get hold of that stuff? I already contacted a local factory whether they had some information for me, but I really don't know where to get started.
    Main rig:
    CPU: I7 920C0 @ 3.6Ghz (180*20)
    Mobo: DFI UT X58 T3eH8
    RAM: 12GB OCZ DDR3-1600 Platinum
    GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
    Intel X25-M G2 80GB, 12TB storage
    PSU/Case: Corsair AX850, Silverstone TJ07
    Xtreme Cruncher xVeinx's Avatar
    Jul 2006
    3
    LN2 is usually provided by a company that also provides O2, Co2, and other gas tanks. Airgas is the one my laboratory gets its LN2 from. That being said, your going to have to find out how to get them to sell it to you since its not for industrial/scientific use. If you can have your school contact the company officially, you are more likely to get it. Good luck.
    Xtreme Cruncher ShootStraight's Avatar
    Mar 2006
    0
    I get DI at the local grocery store. As far as LN2, I say go to an industrial gases supplier. Call a welding shop for recommendations.
    If it were me I'd try to figure out how to do it with DI. Safer, since your already playing with volatile propellants. One less thing, IMO. Probably cheaper too, since you'd need a dewars container to hold the LN2, whereas DI you could just use a cooler.
    Play safe!
    -SS
    Administrator sierra_bound's Avatar
    Dec 2003
    Northern California
    0
    Yes, most industrial gas suppliers would have LN2 as well as dry ice.
    When I used to run benchmarks with dry ice, I used a cooler I bought at Wal-Mart. Whenever I went to the supplier to get more DI, the worker who loaded it into my cooler would say, "You must be throwing a big party tonight."
    Xtreme Cruncher littleowl's Avatar
    Oct 2005
    BFE
    0
    you can buy dry ice at meijers if you have one of them around! as for LN2 you will have to go to a gas supplier to get it as far as I know.
    Jun 2005
    the Netherlands
    3
    Thanks for the input. I'll contact school to see if they can do something as well
    Main rig:
+ Reply to Thread
