+ Reply to Thread
Results 1 to 12 of 12
Thread: G.skill 2gbhz died FOR NO REASON?
    Xtreme Addict Falkentyne's Avatar
    Sep 2004
    West Covina. CA
    2
    I was in maple story today and suddenly I got a white screen with the sound looping. And the screen 'turned' off and on, almost as if VPU recover tried to kick in. Suspecting the video card, for obvious reasons, I turned off the computer and replaced the X1950xtx with a PCI video card...NO POST.
    Then I remembered what happened with my G.skill memory back in March, so I took the memory out and used a 1 gb stick of Corsair xms....POSTED fine.
    I tested BOTH sticks of the g.skill. BOTH sticks are as DEAD as a DOORNAIL.
    Using 2 GB of corsair now.
    Can someone explain WHAT THE HELL HAPPENED?
    How do TWO STICKS of memory die at the EXACT SAME TIME?? Simultaneously?
    (note computer was rebooted about 3 days ago).
    And furthermore:
    The system was COMPLETELY at stock. 2.93 ghz C2D X6800, 266 fsb, memory voltage at stock (2.0v--this is stock), timings cas 3-3-3-8. Asus P5WDH. I have run the system very occasionally (not for more than a few hours over the last few months, and no longer than a couple of days total) at 3.6 ghz with memory @ 2.2v cas 3-3-3-8.
    So what the hell happened here?
    This is my SECOND RMA of G.skill. The first two sticks died (also suspiciously) back in April...
    Banned
    Sep 2007
    0
    OVerclock = OVerkill
    Sep 2004
    West Covina. CA
    2
    The computer was running at stock. Did you read my post at all?
    Xtreme Addict Knight's Avatar
    Sep 2006
    1
    Voltage spike?
    ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Intel i7 3770k
    ░░░░░░▄▄▄▄▀▀▀▀▀▀▀▀▄▄▄▄▄▄░░░░░░░░░ ASUS GTX680
    ░░░░░░█░░░░▒▒▒▒▒▒▒▒▒▒▒▒░░▀▀▄░░░░░ ASUS Maximun V Gene
    ░░░░░█░░░▒▒▒▒▒▒░░░░░░░░▒▒▒░░█░░░░ Mushkin 8GB Blackline
    ░░░░█░░░░░░▄██▀▄▄░░░░░▄▄▄░░░█░░░░ Crucial M4 256GB
    ░░░▀▒▄▄▄▒░█▀▀▀▀▄▄█░░░██▄▄█░░░█░░░ Hitachi Deskstar 2TB x2
    ░░█▒█▒▄░▀▄▄▄▀░░░░░░░░█░░░▒▒▒▒▒█░░ FSP 750W Gold
    ░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░░ Fractal Arc Mini
    I am Xtreme afireinside's Avatar
    Aug 2003
    Cherry Hill, NJ
    0
    I had 2 sets of HZ die to. D9 just dies, randomly. Voltage doesn't matter.
    Phenom II 940 BE / ASUS M4A79 / HD5770 Crossfire
    3770mhz CPU 2600mhz NB | DDR1040 5-5-5-15 | 900/1250
    I am Xtreme safan80's Avatar
    Oct 2004
    U.S.A.
    2
    my g skill ram is working fine, but I don't run them at cas 3 or t1 timmings. Do you have good air flow in your case? what PSU are you using?
    Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
    LSI series raid controller
    SSDs: Crucial C300 256GB
    Standard drives: Seagate ST32000641AS & WD 1TB black
    OSes: Linux and Windows x64
    Xtreme Cruncher road-runner's Avatar
    May 2007
    Conroe, Texas
    0
    Just had one stick die out of a 2Gb set of HZ, was one month old running 24/7 @ 2.2 volts with fans on it.
    Sep 2004
    West Covina. CA
    2
    I have a Lian-Li PC-777 case. PCP&C Silencer 750W PSU. Airflow is decent. (2 front fans, one rear exhaust). Not sure what in-case temp is as speedfan reports 0C with Maple story running.
    I can understand one stick dying, but why would -both- die at the exact same time, from a perfectly working condition, when you are not even overclocked and overvolted? Running RAM at cas3 isn't supposed to kill it...even then--BOTH sticks at the exact same time?
    AFAIK there wasn't a voltage spike...but who knows. Doesn't make sense, though...
    When the computer crashed, Maple story was running and the screen was -totally- white, and acting like it was a video card related crash (VPU recover tried to kick in). Then no POST, until I changed dimms.
    Now it's possible it *was* a video card crash, and the RAM was already 'dead' somehow. I really don't think dead RAM can trigger a video card crash unless somehow the error actually -causes- the video to crash and VPU recover attempts to restore but fails. Oddly, when the first 2 sticks I had failed, the RAM was working until I powered off the computer (no crash), then when I powered on again: nothing. Both sticks dead.
    Did anyone with dead sticks (that died suddenly, so you can't even memtest it) find out if it may be SPD corruption? (but again how at the same time?)
    100% Load 24/7 [XC] 4X4N's Avatar
    Mar 2005
    Seattle
    0
    Funny seeing this. I just had both sticks of 6400HZ die on my son's computer. Running 8x425 4-4-4-15, @ 2.1v with a 120mm fan over them. Have been running them this way for months. His game froze up, he went to restart, and no post. Tried both sticks separately in 3 different boards. No boot in any of them. Looks like it's off to rma.
    Main Rig
    i7 2600k l Asus P8P67 l 2x2gb Gskill l GTS450 l Venomous X l XClio 680
    G.Skill USA Tech GSKILL TECH's Avatar
    Sep 2005
    0
    i have no idea why they go bad so easy. i only know they are micron.
    maybe is the time change to promos?
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Sep 2004
    West Covina. CA
    2
    Gskill tech, what do you mean?
    You mean you may change your chips to promos? I didn't understand.
    I'm using my 2 GB of Corsair XMS as backup right now (i think it's promos chips), as I haven't seen any problems with these dying yet.
    No one at g.skill has been able to identify the cause of the problem?
    When you got sticks returned that were completely dead, what did you find out was wrong with them exactly? Did an IC fry on the PCB or was it a corrupt SPD? This knowledge might help others...
    It's clearly not the chips dying from too much voltage (two dimmms would not fail to post simultaneously...)
    Sep 2005
    0
    Quote Originally Posted by Falkentyne View Post
    i mean it is good time to change to like F2-6400CL4D-2GBHK, F2-6400CL4D-2GBPK those item.
    the problem is on micron IC nothing else
+ Reply to Thread
