+ Reply to Thread
Results 1 to 5 of 5
Thread: 4gb on P5B Deluxe for overclocking
    Xtreme Enthusiast it_burns_when_i_pee's Avatar
    Aug 2007
    South Wales
    0
    I havent yet, but i am going to have a go at overclocking (i have not done any since the early athlon xp)
    The ram i have is Geil 2x1Gb 4-4-4-12 PC6400 and seen a few on ebay go at a reasonable rate. Only the seller advised me that 4gb may be a problem with this board if i overclock
    Can anyone advise? If it will effect it i assume it would be better overclocking and sticking to 2gb than jumping to 4gb and keeping at stock speeds
    "Never under estimate the predictability of stupidity"
    Q6600 @ 3.6 / TRUE (both lapped)
    P5Q Deluxe
    4Gb Corsair DominatRIX 1066Mhz
    1Gb HD 4870 + HR03-GT
    2 x 320gb WD3200AAKS RAID-0
    Thermaltake Toughpower 850
    X-Fi Fatality / SR-71 Amp > Sennheiser HD650's & Logitech Z-5500
    HP W2207 TFT
    and me??? Powered by absolut, kebabs, tramadol & a new liver
    Xtreme Member doakh's Avatar
    May 2007
    Portland, Oregon
    0
    I am running the following 24/7. I am not a gamer, but I do a lot of number crunching.
    ASUS P5B Deluxe (Bios 1212) Vista x64
    E6600 running at 399 x 9
    4x1GB G.Skill 6400 HZ (1:1) 4-4-4-12
    Sapphire X1950 Pro 512MB (621:1592)
    PCI Express Frequency: 101
    vMem: 2.05
    vCore: 1.5125 (1.50 actual) I am testing 1.50 (1.48 actual)
    vFSB: 1.40
    vMCH: 1.45
    vSB: 1.50
    vICH: Auto
    I have everything enabled in the Bios under 'Advanced'/'CPU Configuration' except 'Max Cupid Value Limit.'
    I wish I would have bought higher Mhz memory as I am only able to boot up to around 3.8 Ghz...425 x 9 and 475 x 8 but I am unstable.
    I have improved my cooling, so I may decide to increase my vCore, but I am afraid I might permanently damage the chip.
    HAPPY MOTORING
    Asus P5Q Deluxe (P5QD1406) || Q9400 at 3.4GHz || 2x2GB Mushkin Redline PC2-8000 || HIS HD 4870 1GB w/ Scythe Musashi (silent) || 501GB Samsung HD || Zalman ZM850-HP || Antec P182 || Windows 7 x64 RTM
    Aug 2007
    South Wales
    0
    Quote Originally Posted by doakh View Post
    vMem: 2.05
    vFSB: 1.40
    vMCH: 1.45
    vSB: 1.50
    vICH: Auto
    HAPPY MOTORING
    hmmmm, i tried overclocking last night, i left all voltages & ram settings to auto and tried 333 fsb and it wouldnt boot. im technically new to overclocking as i havent looked at the scene since early athlon xp's. i feel i should try overclocking before investing in another 2gb. would be nice to achieve your overclocking results though - thats something for nothing
    P5Q Deluxe
    HP W2207 TFT
    May 2007
    Portland, Oregon
    0
    Set your vCore to 1.30 and your vMem at your stock voltage, probably 2.0 and leave it on DDR533 (1:1) for now. Everything else on auto. It should post at 333FSB. You then be able to reduce the vCore a little by experimenting. Turn off 'CIE Support' and 'Speedstep' for now. Go the ASUS Support......http://vip.asus.com/forum/topic.aspx...en-us......and some of your questions will be answered.
    Aug 2007
    South Wales
    0
    cheers for the info man, will try it later. only i set ram to 667 thinking that 333.3 x 2 is 667 ?!?!
    forgive me as i am still learning all this. last time i overclocked you only adjusted multiplier and fsb
    P5Q Deluxe
    HP W2207 TFT
+ Reply to Thread
