Hm strange, I don't notice this?
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
can i use tape instead of zip ties for the cables? It doesn't conduct electricity so im assuming its fine.
also getting the vibration noise on the side panel (140mm yate loon). seems to be causing the side panel (by far the worst part of this case) to resonate but i'm not sure
I have fan noise if using anything faster than 5V or ~600rpm
reason is my panel is concaved and my fan grilling is slightly concaved too, my upcoming solution is to hammer or stamp out the grilling slightly by a few mm that should do it.
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
Anyone knows if the IFX-14 can fit into the CM690? The back extended heatsink especially.
I have this case as well and with a Thermalright Ultra 120 Extreme, and you can definetly still fit two fans on the top , but i find it pointless because that would just take air away from my fan on my Ultra 120. But i love this case and it's always so cool my temps are always sub 20C.
EVGA 680i SLi :: E6750 @ 3.92GHz
Thermalright Ultra 120 Extreme w/ Scythe "Ultra Kaze" 133CFM Fan
BFG Tech 8800GT OC2 @ 760/1884/2160MHz :: 2GB Crucial Ballistix Tracer PC6400
Cooler Master RC690 Case :: Ray Samuels Audio Predator DAC
Creative Sound Blaster Audigy HD Sound Card 5.1 (OLD SCHOOL!)
3DMark06 - 14417 GOING FOR MORE!
http://service.futuremark.com/orb/re...0&UID=13344521
- E6750 with Scythe Infinity- 120mm PWM
- 2x2GB ReaperX HPC PC2-8000
- Seagate 7200.10 500GB & 320GB
- Asus Maximus Formula S/E
- MSI NX8800GT-T2D512E-OC
- X-Fi Fatal1ty Platinum FPS
- Antec Quattro 850W
- Logitech DiNovo Edge & MX1000
- in a LianLi
^^^ wow what is that over your CPU and ram??
- in a LianLi
That is one of these: http://www.newegg.com/Product/Produc...emini%2bcooler
Anyone here done a turn the HDD cage 90 degrees mod yet?
I have seen it done on another forum, it worked quite well, I'll try find the link soon.
Core 2 duo E8400 @ 4.2Ghz | Swiftech H20 Apex Ultra Plus | 2GB OCZ Reaper HPC PC8500 @ 1066 4-4-4-4 | 320GB WD + 640GB WD | 512MB 8800GT @ 700/1900 | Antec 900 | 22" Dell E228WFP + 22" Asus VW222U | Logitech G9 + G15 | Asus P5K-E WiFi | Running on a 380W Antec NeoHE
- Me @ HWBOT
- Me @ HWBOT
hell of a case
Mine will be here tomorrow.
some pics on the way!
Raidmax ATOMIC - Core i7 3770s + Corsair H70 // Gigabyte H77N WIFI // Corsair Vengeance 2x4GB 2133mhz // EVGA GTX1060 ACX2.0// Kingston SUV400 480Gb // Sharkoon SFX500L
It takes some work, dremeling through excess plastic and metal on this case, and replacing the stock fans (among other things) to really see a temp difference with this case. (remove the top plastic grilling and put the top fans so they act as exausts over your hot cpu.) Still a beutiful awesome case that's ripe for mods, i'll upload a few pics in a day or two when the epoxy on my pump dries (long story)
As Los Alamos director J. Robert Oppenheimer watched the demonstration, he later said that a line from the Hindu scripture the Bhagavad Gita came to mind:
"I am become Death, the destroyer of worlds."
Test director Kenneth Bainbridge in turn said to Oppenheimer, "Now we are all sons of b**ches." wiki
I have thought about doing it. ( i have this rivet gun that i have never worked up the guts to use). I decided not to since it would give me less room to work, and might cramp my video card, a year or two down the line. (also, the fans i use are two thick to put up in the front part anyway. Despite that, i still have ten 120mm fans in the thing.
