Nice review Nick and a nice case..Good design.
The XS WCG team needs your support.
A good project with good goals.
Come join us,get that warm fuzzy feeling that you've done something good for mankind.
Bah, just tried, won't fit. Theres like a plastic shroud built in for the top 2 fans to guide airflow and that prevents it. I don't think its removable either. You could possibly gut it out and it might work, but it'd be close.
You can see it there. If you ripped out that pattern plastic crap and the guide around it it'd be fine.
Core i3-550 Clarkdale @ 4.2GHz, 1.36v (Corsair A50 HS/F) LinX Stable
MSI H55-GD65 Motherboard
G.Skill 4GBRL DDR3-1600 @ 1755, CL9, 1.55v
Sapphire Radeon 5750 1GB
Samsung F4 320GB - WD Green 1TB
Xigmatek Utgard Case - Corsair VX550
So is there enough room to mount an MCR-220 below the fans or I won't have enough clearance?
I think it depends on your mobo. With my mobo it'd probably hit my RAM.
could repost that picture or e-mail it to me. I'm quite curious about it. mk8913@aol.com
Nice review, just what I was looking for! Does the buttons feel cheapish and do you think they will last?
If you mean the power button, it's in a horrible spot. How's lower right corner and it pushes @ an angle sound, lol? There's an equally lame reset switch as well. As long as you've got a board that can turn on via usb/ps2 or the uguru clock, it's a non issue tho. Now the top USB/Firewire/Audio/eSata jacks rock.
Makes me want a new case
My Antec Plusview needs to retire, it's getting outdated, being 80mm fans all-around, except the rear exhaust fan...
And at sub-100$ it seems nice
Can you measure if an 8800GTX could fit in there?
Best Regards
Silverstone RAVEN RV02|
Core i5 2500K@4.4GHz, 1,300V|
Corsair A70|ASUS P67 Sabertooth|Creative X-Fi Titanium Fatal1ty|
Corsair Dominator DDR1600 4x4096MB@DDR3-1600@1.65V|Sapphire HD7970 3GB 1075/1475MHz|
Corsair Force F120 120GB SSD SATA-II, WD Caviar Black 2x1TB SATA-II 32mb, Hitatchi 320GB SATA-II 16mb|Silverstone DA750 750w PSU|
I am thinking about dremel'ing the grid off the fan mesh on one of mine, The plastic waves part I was considering removing every other one. Thoughts?
Bleh, stupid CM couldn't allow you to fit the 120mm between the molding. Doing some measurement, if CM added another 20mm to the molding, this case would be perfect for water cooling.
Not to hijaak NickS, just thought you the perfect people to ask on this,
My galaxy, temporary solution, does not fit quite right it stradles the two vents on the bottom. Do I run it upside down even with the risk of venting into the case?
EDIT: NEVER mind! Suppose its too late to hide the post - The big fan is the intake. Still hard to fit in the case, but I love these 690's
Hmm... looking closer at your pics, it seems that all the fan-slots are capable of supporting even 92 and 80mm fans... Could you check to see if that's right for me? I've got 3 80mm fans I could use in the empty top-slots, so I wouldn't need to buy too many new 120mm
Best Regards
