As you know, overclocking HD2900XT in CrossFire is not supported by any available software tool, not even BIOS modding tools like Rabit. I don't have the knowledge to add such support to current software, but what I do know is that the videocard internal clock frequency's are all being build upon a 27MHz clock oscillator/crystal. This has been like that for ages (well, almost ), check some of your past videocards, 99% of the time they will have a 27MHz crystal/oscillator somewhere. If you can't overclock the card via software then you can still alter the clock frequency by changing the crystal oscillator soldered on the VGA card.
In my previous experiments you saw how I changed a 27MHz crystal with a 29MHz crystal and that it boosted the 'stock' performance by 9%. You can do the same with your HD2900XT, I've looked at some of the pictures I took for the HD290XT review and pointed the to be changed 27MHz oscillator:
Go to your local electronics dealer and ask for the same thing but with a 29MHz frequency instead, then replace them and see what happens. Worst case scenario is that you have to put the stock 27MHz crystal back on the card, no damage should accour to your card though.
Sidenote: alterering the reference 27MHz clock boosts every single clock frequency that's made on your HD2900XT. This means not only GPU, but also memory clock. If you card doesn't boot it could be possible that the memory can't scale that high, or visa versa the GPU could be holding you back too. Besides that it also changes communications between onboard VGA chips and has also effect on communication with your TFT screen. It could be possible that you've to lower the resolution in Windows because the refresh rate is too high.
