Results 1 to 2 of 2
Thread: How to change FSB with P5K and 340J.
    Jul 2002
    Belgium
    I know the motherboard doesn't support the CPU, only it boots without a problem.
    If I try to change the FSB, minimum 200 must be used.
    On air (for the moment) that's a problem.
    Tried Setfsb, worked perfectly on the E6850, it doesn't work on the 340J.
    Any idea if it's possible to go below 200fsb on the P5K ?
    Since it supports the cpu (booting and testing it in windows) there must be a way to get that fsb lower.
    http://processorfinder.intel.com/det...px?sSpec=SL7TP
    Idea's welcome.
    Dell XPS M1730 - X9000 @ 3400mhz-4096MB 667MHz DDR2 - M8800GTX SLI- 17"WUXGA+
    EVGA E762 4Way SLI Classified - 980X @ 6Ghz Lnē 6GB Dominator - MSI 5870 Lightning
    WWW.MADSHRIMPS.BE - Being Mad Doesn't Hertz You
    Jul 2002
    Belgium
    Put the modded prom on it, 220 fsb was easy
