help with tecs on vid-card
ill start today and get the copper plates for the tecs. ill use 4 40x40mm ~30W tecs to cool the memory of my 4200. ill use one tec on each pair of memory, the only problem so far is that the pelts are open on the sides. i heard i should close them, but how? can i use a plain hot glue pistol? or should i get some silicon plastic stuff for bathroom and window insulation?
i dont know how much volts those tecs need, probably 15 but im not sure... could i kill them with 12v if they need less?
whats a good way to connect them to my powersupply?
should i plug them to my systems 350W powersupply (fsp fortron, has a good 12v line) or should i use an old 250W psu or maybe use both psus together?
the fsp 350W psu has 16A on the 12v line, the samsung 250W psu has 6A on the 12v line.
- You may not post replies
- You may not edit your posts
Forum Rules
