How do I get my OCZ ram cooler to fit over ram chips with tall heat spreaders? Also, why does my OCZ ram cooler contain two different types of stand offs? Their only difference between the two is that one has a peg on it and the other doesnt.
MM Extended U2-UFO CYO (Duality front, Standard back, Horizontal Mobo brace) Anodized Black || eVGA X58 || Intel i7 920 || 6 GB Corsair Dominator PC3-12800|| eVGA 295GTX || Asus Xonar Essence STX || VisionTek 650 TV Tuner || 1 300GB WD Velociraptor || 1TB WD's Black Ed. || LG 22X DVD-Writer || Lite-On 20x DVD-Writer || Corsair CMPSU-1000HX PSU
CPU Loop: DDC-2 w/ XSPC Reservoir Top -> Swiftech GTZ -> Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
GPU Loop: DDC-2 w/ XSPC Reservoir Top -> (Koolance VID-NX295 FC block) ->Thermochill PA120.3 (Push: 3 Scythe S-Flex G)
Chipset Loop: DDC-2 w/ XSPC Reservoir Top -> Alphacool Silentstar Dual HD waterblock enclosure -> Bitspower Black Freezer eVGA x58 MOSFET-> Bitspower Black Freezer eVGA x58 NB -> Thermochill PA120.2 (Pull: 2 Scythe S-Flex G)
2 x Dell 2408FPW LCD || Logitech Z-5500 Digital 5.1 || Logitech G9 Mouse || Logitech G15 LCD Keyboard || Logitech Quickcam Ultravision || Sennheiser Headphones
Hi, the 2 type of brackets just allow a different mounting options. The one with the peg is a little secure and the other is in case you need to shift the unit to one side off of center.
Unfortunately the unit was not designed for tall heatspreader applications. It only works with "normal" height heatspreaders. Sorry.
Does this mean that the OCZ XTC ram cooler is incompatible with OCZ reaper RAM, which probably qualifies as having "tall" heatspreaders?
Lian-Li PC-Q11W mITX - Core i5 4590 - MSI Z97I Gaming AC - 8GB DDR3 RAM - Seasonic 460W fanless - Intel SSD 520 240GB - 2x WD 4TB HDD
Cooling: XSPC AX480 Quad rad - 4x NB-eLoop B12-1 @ 650 rpm - EK-D5 Vario X-RES 140 - EK-Supremacy CPU block - EK GPU full cover block
Video: nVidia 670 GTX - Achieva Shimian QH270-IPSB @ 2560x1440 - Ergotron LX LCD arm | Audio: Yamaha RX-V467 receiver (via HDMI) - Tannoy Mercury F1 5.1 speakers
