When are you going to change the Stealth as well ?
damn thats pretty HOT.. but what about staining, doesn't copper start to loose its shine after a while.. or is there some sort of metal varnish covering the copper housing.
Evga X58 sli under cascade
http://www.xtremesystems.org/forums/...d.php?t=219788
Evga X58 Sli ultimate overclocking/ overview/ discussion thread
http://www.xtremesystems.org/forums/...d.php?t=221082
proud owner of E8600 Q822A435
What about a Delrin or Acrilic top. I've seen somewhere that somebody made a custom Acrilic top, it look very sexy, plus no aluminium. I have the opinion that swiftech should go back to delrin tops.
I believe the common fear with delrin and acrilic tops for the GTX are how they handle the bowing. It is unknown at this time whether they crack or bend when bowed.
__________________
Budgets, Bling, We Need Not These. We Have Science!
"Common fear"
What common fear? Like the boogie-man, they don't exist.
Update
Word on the street is that Swiftech may sell a complete Copper version of the GTX. This would bring the price of the GTX up about $10 more.
http://www.swiftnets.com/forums/viewtopic.php?t=286
OPP
Thank you OPPAINTER for the heads up I will be placing an order as soon as it is in stock at Jab-tech.
Yes, the acrilic top was from someone in Germany and it was just a prototype or something for his own use. It would be nice if they get comercialized, like alphacool´s or petra´s top for the DDCs.
Regarding the bowing, I belive there are Apogee GTs (delrin top) being bowed with a thiker o-ring. What is more, the bowing king of the hill (Fuzion) its made out of delrin. I don't think thats the reason. In swiftech they like alu tops for their blocks. I still remember the galvanic corrosion problems I had with their MCW5000 series. No alu for me. Dosen't matter how high grade treatment they put in it.
worth a try i guess, thanks.
DFI LT X38 qx6850 @ 3.6g TJ-07BW
PA120.3/mcp655/GTX/mcw30+Tline+GSkill 4g
AHFDx2, 1T Samsung F1x2, Evga 8800gtx, W0132RU
Dell e1705 t7400 2g 200gHD 7900gs
http://www.heatware.com/eval.php?id=45541
*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
"Artificial intelligence is no match for natural stupidity."
Thank you!!!
I totally Agree with nikhsub1! This is how it should have been from the start... no aluminum and no dye... and honestly $10 is nothing to warrant risking your loop with aluminum... but lets not get into that now because this is happy day!!!
Now I just need to hear the final work on whether the GTX will be sold with the copper block or not and then I will purchase 1 or 2... Glad to see a top only for sale for those who already purchased the block...
Yin|Gigabyte GA-Z68X-UD5-B3|Swiftech XT -> GTX240 -> DDC+ w/ Petra's|2600K @ 5.0GHz @1.368V |4 x 4 GB G.Skill Eco DDR3-1600-8-8-8-24|Asus DirectCUII GTX670|120 GB Crucial M4|2 x 2 TB Seagate LP(Raid-0)|Plextor 755-SA|Auzentech Prelude 7.1|Seasonic M12-700|Lian-Li PC-6077B (Heavily Modded)
Squire|Shuttle SD36G5M| R.I.P.
My Heat
i5 2500k @4.5ghz Raystorm
Asus P8Z68-V Pro/Gen3 16gb(4x4) G.Skill PC12800 Ripjaws X
x1900xt MCW60
Rad: Thermochill PA120.3 3YL SL/ Pump: DDC2 w/ Petra's top 7/16in ID masterkleer
Corsair 120gb Force GT SSD/ 1TB WD Black Caviar SATA
X-Fi music/SH-203B/H62L/LH-20A1L
Corsair HX620w /Acer AL2223W/modded TJ07
Whooo bloody last is all i can say! $40 thats cheap for us Brits!
I'm going to get mine nickel-plated (I admit, I'm a nickel-plating junkie! ... http://www.xtremesystems.org/forums/...d.php?t=156308)
Any idea when we will see the complete Copper set for sale or is this just a rumor?
Thanks,
Monk0101
MB - Badaxe2 (bios 2797), CPU - QX6700 (cooling MCP655, MCR320, Fusion)
MEM - 4x 1gb Corsair Dominator PC8500
HD - 2x Raptor 73gb, 2x Raptor 150gb Raid0, 2xSamsung 250gb Raid 0
DVD - Plextor PX-760A
Video - EVGA 7900GT Super Overclocked
PSU - PC Power & Cooling Silent 750
Audio - Sound Blaster X-FI Extreme Music
OS - WindowsXP Pro SP2 & Vista 64
Case - CM Stacker 810 ATX
I dont know why, but the bare copper doesn't attract me. I guess im like virtualrain... I hope the regular aluminum plated top will never cause me any troubles. Perhaps before it causes any troubles Ill be replacing the waterblock because of a socket change...
Intel Core i7 3770K | Asus Maximus V Gene | 16GB DDR3-1600 | Asus GTX 670 directCU TOP | Intel 320 120GB | WD Caviar Black 1TB | Enermax Revolution 1050W | Silverstone TJ08-E | Dell UltraSharp U2711
I'm still waiting for someone in the UK to actually have the stealth in stock, so perhaps I might be able to buy one of those in a year, or two.
With any luck......
$40 just for the top.
My heatware: http://heatware.com/eval.php?id=41179
cpu: e6600
mb: evga 680i
ram: Ballistix 8000
video: XFX 8800 GTS
pw: 750 Quad
