Hello everyone this is my first post at the xtremesystems forum
So to the question, I resently bought a prometeia cooling system and its working great, youst have one problem. My L1 bridges on my t-bird, wich are painted with conductive silver paint stop working after a short while in the system.
I talked to the guys at chip-con the company that sells the prometeia and they said they had heard of this problem before. Cause of the low temps u get on the cpu the silver somehow looses contact with the cpu and the unlocking stops to work.
U guys r some of the best and I thought maybe someone has some other way I could unlock the cpu to get it to work?
Would the old penciltrick work better? I remember some company sold a peice of tape with small peices of wire under it or something , or should i paint over the bridges with something like nail pollish would that help?
I painted the bridges with the silver let it dry for 40 mins said on the container it would dry in 20, and then protected the whole thing with a bit of tape.
