+ Reply to Thread
Results 1 to 7 of 7
Thread: Damn FSB wall with Abit IP35 + E6850
    Nov 2004
    Sweden
    1
    Running a Abit IP35 Pro with a E6850. When i go with air i can¨t go over ~485fsb, doesn´t matter what voltage i set. And when i tried my SS i could go up to 536fsb but after that is stopped. Tried different voltage there to.
    So the BIG question is, should i look for a new cpu or motherboard ?
    http://techsweden.org
    Asus Maximus Formula V, Ivy 3570K, 8GB G.skill PC12800, Asus HD7970
    Xtreme Member michaLcoughliN's Avatar
    May 2007
    Burlington Ontario
    0
    Why would you want to look for a new cpu / motherboard. personally makes no sense. sice your can run 9xcmos . Apparently it appears your saying 485fsb x ? 8 would still give u 3.8g which isnt bad.
    But you should be running at 9x multi to achieve a much better / higher overclock.
    So why are you wanting to look for new hardware when what you got is more then enough.
    Motherboard Asus P5K Deluxe
    CPU E6850 @ 3.8ghz 1.5Vcore
    Ram OCZ Reapers Pc8500 2gb 4:4:4:12
    Hard drives 1 x 74gb Raptor 10k + 1 x 250gb Cav for storage
    Case Lian Li 1200bPLUS2
    PSU Corsair 620w
    GPU EVGA 8800ULTRA (660/1080) 13223 on 3dmark06
    Watercooling MCP655, Micro res, Mcr320, Fuzion, EK full coverage GPU block
    Nov 2004
    Sweden
    1
    Because i want to go past 536 fsb and maybe achieve higher cpu clock ^^
    Jul 2007
    0
    trubodream, trust me its not worth the hassle, unless u have some extreme cooling and shooting for 5ghz or somethine, i was able to get my board 543 fsb orthos stable, with small fft's. but u know what the benchmarks were slower at the same speed with higher multiplier and lower fsb, why because the northbridge loosens the timings and it takes a performance hit as u increase the fsb. i would never go for higher fsb because the raw speed matters to me the most. use higher multiplier and u will be a lot happier and it will be faster. hey than again its ur computer and do what satisfies u the most lol, this is just what i think,
    Q9450(VID 1.2375) 3.9GHX 488*8 1.32V LOADED
    Asus P5Q-E
    CRUCIAL BALLISTIX 3GB RUNNING@980MHZ 5-5-5-12
    RADEON HD 4870
    OCZ VENDETTA 2
    WINDOWS VISTA 32BIT
    average room temp 72-76c
    Dave's Mentor! zsamz_'s Avatar
    May 2007
    montreal
    4
    i can go up to 575 but not worth it
    510 fsb is good enough for 24/7
    if you really want to ho higher you gonna need more juice on nb n u better have good cooling
    maximus IV extreme gtx580
    gigabut p67-ud7
    p67 sabertooth
    2500k+2600k
    antec 1200watt
    EVGA classified 760
    920 Batch# 3849B018 4.985ghz@1.52v gtx285 ftw sli
    OCZ3RPR1866LV6GK hypers
    dfi ut p35 rampage extreme
    gigabut p35c-ds3r bios suks
    gigabut x38-d6q dead thank god
    ballistix 8500 1240mhz@2.02v
    Xtreme X.I.P. metro.cl's Avatar
    Aug 2004
    Chile
    0
    Quote Originally Posted by Turbodream View Post
    If you are looking for high clocks for benching, i would try a new CPU.
    What volts did you increase in the bios? i'm not sure if the mobo has all the right volt adjustments
    Xtreme Legend crotale's Avatar
    Nov 2002
    Sweden
    0
    Have you tried 1:1?
    IP35 seems to dislike some memories.
    "In mild doses, ethylene produces states of euphoria, associated with stimulus
    to the pleasure centres of the human brain."
    Intel benching: 3DMark Vantage: E69642, P37253, H30363, X22138
    Swedish Overclocking Champion 2006 - Celeron Mobile 1400 @ 4243MHz - 203%
+ Reply to Thread
