+ Reply to Thread
Results 1 to 7 of 7
Thread: Building a Dual CPU - Quadcore system
    Aug 2006
    0
    Hi I would like to build a Dual Quadcore CPU system, is this even possible to build by oneself or I just have to buy an already DELL server?
    I just want to have a fastest video editing system using 2 Quadcore CPUs.
    my current system is a dual core E6600 with 2 gigs of ram.
    I dont know where to even buy a dual cpu motherboard compatible with Q6600
    please help?
    thanks
    Xtreme Cruncher SoulsCollective's Avatar
    Jun 2007
    Perth, Western Australia
    0
    Try this and a pair of these from NewEgg, if you're American which I shall assume you are.
    Rig specs
    CPU:
    i7 950 @ 4.2GHz Mobo: eVGA Classified 760 RAM: 3x2GB Corsair DDR3-2,000 Dominator GTs @ 2,000, 8-9-7-24
    VGA: Crossfire Sapphire HD6970s SSD: OCZ Vertex 2 60GB HDD: 6x WD6400AAKS in RAID-6 powered by Highpoint RocketRaid 3520
    SFX: Auzentech X-Fi Forte w. OP637AU PSU: Corsair HX-1000 Case: Silverstone TJ-09 modded for WC OS: Win7 Pro x64
    Liquid-cooled
    -=- EK-Supreme HF -=- EK Classified FC -=- 2x MCR120 + MCR320, Scythe Gentle Typhoon 1850s -=-
    2x MCP355 w. XSPC Dual-DDC Top -=- EK-Spin bay res -=- 7/16" black Pro-LRT w BP compressions -=- Aquaero w. Powerbooster
    Peripherals
    3x Dell U2311H (Eyefinity) -=- Audio Technica ATH-AD1000 -=- Razer Mamba -=- Microsoft "Natural Ergonomic 7000" keyboard -=-
    Foundational Falsehoods of Creationism
    I am Xtreme tiro_uspsss's Avatar
    Jan 2006
    bouncing between Perth & Sydney
    41
    plenty of options @ Newegg - just look under motherboards>server motherboards - there will b plenty of dual (& quad) socket mobos... no u dont have to buy from dell to get this type of stuff lol...
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    the yummy FOOD
    thread
    heatware / ebay
    Xtreme Enthusiast RLM's Avatar
    Mar 2006
    Back in Thailand for now.
    0
    please help?
    First off my knowledge is limited on these setups, but...
    You won't find one for the q6600. You'll need to look at xeons instead. Something like the xeon 5355s. Basically chips to fit the 771 socket instead of 775.
    Motherboards I believe you would need to look at something like supermicro or tyan and you would need special ECC ram.
    The one advantage of a setup like this is that you can always buy one chip now and another one later.
    RLM
    Edit: Maybe http://forums.2cpu.com/ would be the best place to look.
    QX9650@4.5ghz Vapochill LS
    E8600 (Boxed)
    Rampage Extreme
    OCZ Gold DDR3 (8500) 1680 7-6-6-20-2T
    4870x2 Vmodded + Ek Nickel
    9800GX2 Vmod + EK H20 (Stored)
    Thermaltake TP 1000W
    Lian Li P007 Case
    Jan 2006
    41
    as RLM said - dual socket Intel (Xeon) is socket 771.
    the RAM u need for these systems is different as well - its FB-DIMM & EXPENSIVE!
    u CANNOT use 'ordinary' Exxx C2D or Q6xxx cpu's...
    the yummy FOOD
    thread
    heatware / ebay
    Aug 2006
    0
    Thanks for the replies, I just reacently learned about the Xeon Penrym's, should I wait for these?
    thanks
    Jun 2006
    Torrance, CA
    0
    You also are extremely limited to the HSF's you use as there are few that are 771 compatible.
    The stock Intel Xeon HSF's are noisy, or you can choose to use the passive lumps of copper they provide for 1U rack mount server configs.
    The CPU looks just like a QX6800 however the mounting points on the motherboard are completely different and therefore require 771 specific HSF's
    A good dual Xeon X5355 motherboard is the Intel S5000XVN-SATA, but there again you are limited, no SLI support, but this board and those chips make one helluva nice workstation with enough RAM.
    I know because I have all the components to build one except the video card which should be here in a few days.
    Be prepared for sticker shock, the CPU's are about $1300.00 each, the mobo is over $500.00 and 8 gigs of RAM is a $700.00 + event or more.
    Top that off with a few hard drives and an 8800 GTX and you are looking at an $8000.00 system.
    The nice thing is that you can choose an Antec P-190/1200 system case and have the dual power supply set up, the Antec P-190/1200 will fit an E-ATX motherboard!
    Intel D975XBX2 (BadAxe2) - QX6800 (G0) Kentsfield - EVGA 8800 GT-KO - (4x1gig) Crucial Ballistix DDR2 1066 @ 4-4-4-14 - Antec P-190/1200 - Modified Koolance Exos2 (added the RP-950+ Speed Control) CPU-GPU-North and South Bridge blocks
    Intel S5000XVN-SATA - Xeon X5355 (X2) - BFG 8800 GTX 768 - (4x1gig) Crucial Fully Buffered - Antec P-190/1200 - MY V-8 Monster soon to be water cooled
+ Reply to Thread
