+ Reply to Thread
Results 1 to 14 of 14
Thread: sinse i installed my new x1950 pro my computer is going crazy
    Dec 2003
    israhell
    0
    yesterday i replaced my radeon 9800 on a new sapphire x1950 pro(agp)
    after i booted up oneof my hard drives begun to make tik noises all the time
    i thought it may be its time to go (4 years old) and disconnectd him
    after that the computer begun to work slow and put blue screens at my face
    when i was copying files
    i putthe radeon 9800 back for now but the computer still works very slow
    i dident had ani blue screens yet
    when the blue screen apeared it said some thing about ATAPI some thing like that
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    44
    What PSU do you have? The X1950 is gonna pull more juice than the 9800 so it could be causing power issues.
    The Cardboard Master
    And put that GPU to work too! Fold for XS
    Main PC: Intel Core-i7 2600k @ 4.5GHz, 8GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 7 Pro x64, water - ONLINE
    Office PC: Intel C2D e8400 @ 3.0GHz, 4GB DDR2-800, GeForce GTS 250, Win 7 Pro x64, air - ONLINE
    Dedicated: DP Intel Xeon LV Sossaman @ 2GHz, 4GB DDR2-400 ECC, Win XP Pro, air - ONLINE
    Family PC: Intel C2D e8500 @ 3.2GHz, 3GB DDR2-667, Radeon X1300, Win 7 Home x64, air - ONLINE
    Jan 2007
    Nottingham, U.K.
    1
    Seconded. I had no end of problems going from a 9800xt to an x1950pro until I got a shiny new 450W psu.
    Xtreme Guru adamsleath's Avatar
    Nov 2006
    Brisbane, Australia
    0
    lol nice sig.
    q9550|GTX480|3x2GBDDR2|P5Q-Pro 1613|640GB WD X2|Hitachi 7K3000 2TB|Vista 32+64 dual boot|BenQ G2420
    Xtreme Mentor Zytek_Fan's Avatar
    Apr 2007
    Idaho
    0
    PSU is prolly the problem.
    "To exist in this vast universe for a speck of time is the great gift of life. Our tiny sliver of time is our gift of life. It is our only life. The universe will go on, indifferent to our brief existence, but while we are here we touch not just part of that vastness, but also the lives around us. Life is the gift each of us has been given. Each life is our own and no one else's. It is precious beyond all counting. It is the greatest value we have. Cherish it for what it truly is."
    The Blue Dolphin alexio's Avatar
    Nov 2004
    The Netherlands
    0
    You may have corrupted your HDD while instability occurred due to overstressing the PSU. That would be a good explanation why the computer still feels slow after putting back the old card.
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Dec 2003
    israhell
    0
    i got a 475 watt HEC psu
    how can i check if the psu is the problem?
    Nov 2004
    The Netherlands
    0
    Quote Originally Posted by punk119 View Post
    It has just 15A continues on the +12v line which is very low for a 475W unit. This may causes your issues. You should at least get a PSU with 20a continues on the +12v line. A good brand 380W+ PSU should be fine
    Blue Reviews:
    Blue Guides:
    Xtreme Cruncher Emerica's Avatar
    Apr 2006
    Tampa
    0
    Quote Originally Posted by alexio View Post
    Yeah you definitely need a better PSU. A Xclio GoodPower 500W can be had for ~$50.
    Workstation :
    Q6600 @ 3.2ghz/Scythe Infinity (Screw mount mod)
    GA-P35-DS3L (F7)
    4GB G.Skill @ 400mhz 4-4-4-12
    BFG Nvidia 7600gt
    WD 250GB SATAII 16MB (OS/Programs)
    Seagate 250GB SATAII 16MB (Storage)
    NEC DVD+/-RW
    Antec NeoHE 550W
    X-Fi Xtreme Music
    Razer Copperhead
    MS Natural Ergonomic 4000 (Best KB ever!)
    Windows 2008 Enterprise Server x64
    Laptop:
    Dell Latitude D610 - Pentium M 750 1.86Ghz / 1GB RAM
    Apr 2006
    0
    ticking is usually a mechanical failure of some sort. I'm concluding what everyone else is too. PSU supplying insufficient power to the hard drive, potentially damaging it, causing your computer to slow down. X1900 series cards are big power consumers.
    -----------------Main Setup-----------------
    Processor: Intel C2D E4600ES @ 3.4 Ghz
    Motherboard: Abit AW9D-Max
    Heatsink: Cooler Master GeminII HSF
    Graphics Card: eVGA 6800GS 515//1320 (hacked SLI)
    RAM: 2x 1Gb GeIL Ultra UDCA= DDR2 800Mhz cas 4
    RAM: 2x 1Gb Crucial Tenth Anniversary DDR2 667Mhz cas 3
    Hard Drive (Primary): 1 x 200Gb Seagate EIDE
    Hard Drive (Secondary): 1 x Seagate 160GB SATA
    Hard Drive (Secondary): 1 x Seagate 300Gb SATAII
    DVD-RW Drive: 1 x Lite-on CD-RW/DVD-RW
    Power Supply: Antec Basiq 500W
    Dec 2003
    israhell
    0
    i got now 5 case fans 2 hard drives and 2 dvd drives
    if i will disconnect some of them will the new 1950 work properly?
    i made a hard drive benchmark on my system and it says my hard drives barley breathing
    how can i fix it?
    Apr 2006
    0
    how can i fix it?
    the ticking sound has to be a mechanical failure. back it up and RMA if you can. If it was a sector problem, you could probably do a low level format and just zero the drive, but I'm guessing that's not the problem. Try unplugging the 5 case fans. Get a personal fan and blow it into your computer instead (actually, this is really efficient and provides great airflow). Get rid of 1 (or both) dvd drives. See if you can cut load to the power supply.
    Dec 2003
    israhell
    0
    thank you all for the help
    i unplaged one dvd and turned off all the fans exapt one
    put in the new video card and its works like its should
    by the way i mannaged to back it up before i removed it
    its 4 years old so i glad it lasted that long
    Apr 2006
    0
    yeah. my mom's drive lasted for about 7 years. Western digital has some pretty good life times too . made this loud ticking noise right before it died poor guy. I've got him in a box with a bunch of old hard drives now. Got it back when 100Gb was awesome and the P4 1.8ghz was second fastest on the market, lol.
+ Reply to Thread
