Hi all,
Ive got a problem with my phaser and Im hoping someone can help.
After working perfectly last night, I went to turn it on this morning only to notice that the temp being displayed on the controller was fluctuating from 19c (which is about ambient) to 30-50c and changing between very quickly.
It is currently reporting about 40-50C.
The unit boots and starts my pc but quickly shuts down reporting "overtemp" as "temp is >10"
Im not sure if the problem is to do with the temp probe or the controller.
Any help would be great.
Thanks.
p.s. I have also found that the colder the evap gets the higher the temp reported on the front led screen, it just loaded up a moment ago with a temp of a -113c...it then went up/down? to 90c and shut off.
