Results 1 to 11 of 11
Thread: Change the fans in my cisco switch
    Moderator
    Nov 2006
    Hi all,
    Its only a very small mod, but I wish to replace the fans in my cisco switch as they are very very noisey.
    I need a 5v 2 pin 40mm 20mm deep fan that is quiet, but the only fans I can find are about £15 each and I need 4!
    To be honest although finding a 20mm deep fan would be good, its not needed, all I need is a cheap, quiet 5v,40mm fan.
    Any links/info about good quiet fans to get would be great.
    May 2006
    UK
    I can only think of QuietPC, was browsing around on their site
    http://www.quietpc.com/gb-en-gbp/products/40mmfans
    i5-750 w/ Thermalright Ultra120X
    Coolermaster HAF-932
    MSI GD65
    2x2GB G.skill Cas7 1600MHz
    Sapphire HD6870
    Western Digital 640GB.AAKS
    2x Samsung F1 1TB
    2x Samsung SLC 64GB SSD
    Pioneer DVR-212BK
    Corsair HX620W
    Creative X-Fi Xtreme Music (dead, using onboard -.-)
    LG W2286L
    I am Xtreme
    Jan 2006
    Australia! :)
    since ur modding & thus voiding warranty - y not go the 'whole nine yards' - cut out 2 holes for 2 x some very quiet 80mm/120mm fans - one for blowing in & the other blowing out. Place them @ opposite ends, thus creating air flow thru entire switch... just a thought which i've considered doing...
    DNA = Design Not Accident
    DNA = Darwin Not Accurate
    heatware / ebay
    HARDWARE I only own Xeons, Extreme Editions & Lian Li's
    https://prism-break.org/
    Moderator
    Nov 2006
    @luckynv
    I did get these
    http://www.quietpc.com/gb-en-gbp/pro...fans/mini-kaze
    But they wont start with 5v
    @tiro_uspsss
    There isnt room, it is a 1u switch with stuff on top and below it.
    and the sides are 40mm
    Nov 2003
    NYC
    maybe one of those blower fans used in 5 1/4 bays?
    Moderator
    Nov 2006
    Quote Originally Posted by Levish View Post
    nice idea!
    Ill have a look and see if I can find one that will work on 5v
    Jun 2007
    Quote Originally Posted by rogard View Post
    Hi all,
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=160117870942
    ... only 10mm thick though, dont know if that matters to you. Also at 25dBA they may not be 'silent', but hey. they are cheap with no extra postage cost for buying four in the UK
    Moderator
    Nov 2006
    Thanks mate.
    just purchased 4=)
    Jun 2007
    Thanks mate.
    just purchased 4=)
    np...glad to help...hope it works out for you
    Intel E6600 (3.6GHz@1.472V)
    Cooled with Thermalright Ultra120X/Delta PFB1212EHE
    Gigabyte GA-965P-DS3(rev3.3) Motherboard
    2GB Geil Ultra DDR2-800 4-4-4-12
    EVGA 8800GTS 320MB (stock-576,1700)
    Samsung SP2504C Sata HD
    Samsung S183L Sata DVD
    Xtreme Cruncher
    Dec 2006
    Reno, NV
    In my experience, These are the approximate starting voltages for your average fan:
    120mm = 2v-4v
    92mm = 3v-6v
    80mm = 5v-7v
    60mm = 8v-9v
    40mm = 9v-11v
    The Low end being a high speed, The High end being a silent fan.
    As an example, these fans would only start at 10.5+v:
    http://www.petrastechshop.com/40scmcafan4c.html
    Hopefully those fans will work out for you- Believe me, I understand how annoying switch fans can be.
    EDIT: I think the ones I just linked are the ones you ordered... Eh, in that case, I'd suggest finding an old 12v power supply (Like one for a printer/scanner/speakers/cell phone, And fit that into the switch, Or keep it external. I've used them before for making black lights out of a bunch of Cathodes, for testing fans, Or just playing with various 12v electronic devices.
    Use the power of your CPU and GPU to contribute to science! Become a member of one of the most competitive teams in the world of distributed computing, help find cures for diseases and various other charitable scientific causes. It's as simple as running a program! Go visit the World Community Grid and Folding at Home Forums for more information on these projects. CRUNCH 'N FOLD!
    Moderator
    Nov 2006
    Thanks for the info m8..just makes me wonder where cisco got them, and what alternatives they had!
    Anyway I got the fans above from ebay and after a bit of soldering they work like a dream.
    I also stuck some zalman ramsink on the network processors, and it seems to be compensating for the slow in air flow
    Quote Originally Posted by kevinbo03 View Post
    120mm = 2v-4v
    92mm = 3v-6v
    80mm = 5v-7v
    60mm = 8v-9v
    40mm = 9v-11v
