+ Reply to Thread
Results 1 to 5 of 5
Thread: Giga P35 DS4 wont install sound drivers?
    Wanna look under my kilt? K404's Avatar
    Jun 2005
    Glasgow-ish U.K.
    3
    Everything worked fine, but reinstalled Windows yesterday, used xpress install on the driver CD and...the sound drivers wont work. I downloaded the newer ones, thinking maybe there was a nick on the CD, but they wont install.
    The install progress bar gets 3 bars from the end, then gives me a failure message. I tried the disk version as well just by themselves and the same happens.
    A bit random. Nothing in my setup has changed.
    Any ideas welcome
    Cheers!
    Kenny
    you sigged that?
    why?
    ______
    Jun 2005
    Glasgow-ish U.K.
    3
    bump! anyone?
    Im having withdrawl symptoms from my music collection and from decent gaming!
    you sigged that?
    why?
    ______
    Jun 2005
    Glasgow-ish U.K.
    3
    Update: If I disable azalia code in BIOS the drivers will install, but still no sound (no errors though). If I then go to BIOS and re-enable Azalia, no sound and error messages to go with it.
    you sigged that?
    why?
    ______
    Xtreme Addict K.I.T.T.'s Avatar
    Jun 2005
    Durham University, UK
    0
    Got a spare hard drive hanging around mate? Might be worth trying to see if it'll work with a clean install...
    The rig
    CPUs: E6300 ES B0 @ 3220 MHz w/1.35v orthos stable | E6600 B2 @ 3400 MHz w/1.43v --> Sold | Xeon 3050 L2 @ 3304 MHz w/1.45v orthos stable
    MoBo: Asus P5K-E WiFi-AP @ 520 x * orthos stable
    Graphics: 256 MB Connect 3D Radeon X1900XT @ 661/828 (core/mem)
    RAM: 2 x 1 GB Team Xtreem PC2 5300 @ DDR1010 4-4-4-8 / DDR1100 5-5-5-12 w/2.25v orthos stable
    HDDs: 300 GB (16 MB Cache) and 80 GB Maxtor Diamondmax 10 drives
    Optical: NEC ND3500AG DVD +/- RW
    PSU: Antec True Power 2.0 550W
    H2O
    Swiftech MCR220-QP | Laing D5 | AquaXtreme MP-05 Pro LE | DangerDen Maze 4 LP | 2 x 120mm NoiseBlocker SX1 fans
    Lappy
    MSI MS1022 14.1" Widescreen Barebone | Celeron-M 360 1.4 GHz @ 1.86 GHz / Pentium M 715A | GeForce 6200 Go | 80 GB Fujitsu HDD | Sony DVD +/- RW
    Waiting for
    Nehalem
    I am Xtreme Leeghoofd's Avatar
    Sep 2006
    19
    download the latest from Gigabyte, remove ya old one first, including the patch from microsoft for HD sound and then install the new driver,worked fine for me... I also had the same issue as you mate...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
+ Reply to Thread
